Long-term Capacitor storage questions
In a discussion about long-term storage of electronic devices with aluminum electrolytic capacitors, it was noted that keeping devices off for extended periods, such as 100 years, would prevent capacitor drying. Regular use may still necessitate occasional capacitor replacements, regardless of usage frequency. The temperature of the capacitors themselves is crucial, rather than the ambient temperature. The lifespan of capacitors can vary significantly based on design and manufacturer quality, especially for devices around 30 years old. The thread was ultimately closed due to it being a repeated inquiry from a previously banned member.
augustaa88
where I live, the temperature varies between 33-35C and humidity ranges from 57-67% without rain, and I have electronic devices manufactured in the early 90s. What is the maximum possible interval for me to energize these all devices and for at least how many minutes to prevent failures in the aluminum electrolytic capacitors caused due to disuse??
This is a bit of a troll like question.
If you can keep the devices turned off for 100 years, you will never have a problem with the electrolytic capacitors drying out.
If you turn the equipment on when you need it, you may sometimes have to replace one or more electrolytics. You will have to replace an electrolytic capacitor now and then anyhow, even if you turn it on sometimes.
The temperature that is important is that of the capacitor, not your temperature. Also, the service life can vary by an order of magnitude depending on design characteristics. Another point is the reputation of the manufacturer and the quality of the components they use. Your devices are about 30 years old, and not knowing how long they were used is anybody's guess on what life is left.
Likes berkeman
Your instincts are good. Turns out this is a sockpuppet of a banned member who keeps asking this type of question here (over and over and over...). This version of him is no longer here, so I'll close off this thread.
Likes Baluncore
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
14K
