Lorentz Transforms - Understanding Time Dilation & Velocity Slope
  • Thread starter Thread starter calis
    Lorentz
calis
I am new here
didnt find the reply to this before
I hope I get lorentz transformations right
he said, that not only we have to shift placement axis, but also shift time axis
I know that the slope for velocity and time dalation must be same, but what formula to use to prove that the slopes are the same. (time delation formula doesn't work)
I am talking about the slopes for the axes for moving body in coordinate system impied by lorentz transformations
en.wikipedia.org /wiki/Lorentz_transformation
I get not equal slopes using time delation formula
You mean, the slopes for the time and space axes of the second frame, as seen in the first frame? The slopes should not be equal, but inverse, like 2 and 1/2, when expressed in units where c=1 (like x=light-seconds and t=seconds). And what do you mean by "time dilation formula"? How would you calculate slope from the time dilation formula?
I understand how to draw velocity axis as seen in first frame, but about time axis I jut know it must be inverse... OK but why is it inverse
What do you mean by "velocity axis" and "time axis"? Is the velocity axis the x'-axis of the second frame as seen in the first frame, while the time axis is the t'-axis of the second frame? The t'-axis is very simple, it behaves just like an object at rest in that frame (since the t'-axis is a line of constant x' coordinate, and an object at rest in that frame will have a constant x' coordinate)...if the second frame is moving at 0.6c relative to the first, then you'd just draw a line that moves sideways 0.6 light-seconds for every 1 second you go upward, so the slope is just 0.6. The x'-axis is the inverse because it goes sideways 1 light-second for every 0.6 seconds you go upward. You can see this by picking two points on the x'-axis, like (x'=0, t'=0) and (x'=10, t'=0) and then using the Lorentz transform to see where they'd be when drawn in the first frame's (x, t) coordinate system:
x = gamma*(x' + vt')
t = gamma*(t' + vx'/c^2)
(x'=0, t'=0) would be mapped to (x=0, t=0), i.e. the origin, while (x'=10, t'=0) would be mapped to:
x = gamma*(10)
t = gamma*(0.6*10) = gamma*(6)
Since gamma is the same in both cases (it's equal to 1/sqrt(1 - v^2/c^2)), we can see the point will be less far from the origin on the t-axis than it is on the x-axis, by a factor of 0.6. So, the x'-axis drawn in the first coordinate system must be a straight line through the origin which goes up 0.6 seconds for every 1 light-second you move sideways.
To put it a more mathematical way:
For simplicity, use units in which c = 1 so the Lorentz transformation between inertial reference frames S and S' is
x^{\prime} = \gamma (x - vt)
t^{\prime} = \gamma (t - vx)
In S, the x-axis is the set of points that have t = 0. To find the corresponding set of points in S':
x^{\prime} = \gamma (x - v \cdot 0)
t^{\prime} = \gamma (0 - vx)
Combining these two equations gives
t^{\prime} = -vx^{\prime}
which is a straight line through the origin in S', with slope -v.
Returning to S, the t-axis is the set of points that have x = 0. Proceeding similarly to the above, the corresponding set of points in S' is
t^{\prime} = -x^{\prime} / v
which is a straight line through the origin in S', with slope -1/v. The two slopes are reciprocals.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
