jtbell said:
In different inertial reference frames, the two currents or charges produce different mixtures of E and B fields, such that the net effect is the same, after taking length contraction and time dilation into account where necessary.
The E and B fields transform together as a tensor (the
electromagnetic field tensor) under the Lorentz transformation.
I'm not talking about different inertial reference, but about two electrons traveling ALONG each other, in PARALLEL, without any relative velocity. What is relative velocity of two particles traveling in parallel?
- "Two electrons traveling in parallel with the same velocity, without any relative velocity, will attract more the faster they are moving." - Do you know about this, you do not know or you claim is false?
Equations are clear about that: F= q(v x B); B= v x q*k*d/r^2
Experiments are clear about that:http://www.magnet.fsu.edu/education/tutorials/java/parallelwires/
Naty1 said:
Sounds like this is an assumption you are making?? just not true.
I'm not making any assumptions, but observations. I'm talking about real world experiments and equations form textbooks.
What do you say is assumption? What is not true?
3DM@rk said:
For example, what is considered "magnetic force" with respect to one frame of reference, may look like "electric force" with respect to another frame of reference (or some combination of magnetic and electric force). However, there are some invariant values, which all observers should agree on, such as
clem said:
Your magnetic field for a moving charge is wrong. You have to use the Lienard-Wiechert magnetic field. Look at an advanced EM text.
It is correct enough to demonstrate how it works, EXPERIMENTS CONFIRM THOSE EQUATIONS, this is general knowledge, high-school physics. This Java applet demonstrates well known and easy to test experiment about Lorentz attraction and Ampere's law: http://www.magnet.fsu.edu/education/...parallelwires/
Parallel wires, what is the frame of reference:
1.) velocity relative to field?
2.) velocity relative to wires?Free parallel electrons (cathode ray), what is the frame of reference:
2.) velocity relative to ...?
