Lorentz Invariance of Propagator for Complex Scalar Field
The discussion centers around proving that the commutation relation [\hat{\phi}(x_1),\hat{\phi}^\dagger(x_2)] equals zero for space-like intervals, specifically when (x_1 - x_2)^2 < 0. Participants clarify that the integrals involved are Lorentz invariant, allowing the transformation of the difference vector x_1 - x_2 without needing to transform the momentum vector k. A key point is that for space-like intervals, a Lorentz transformation can be found that negates the vector, leading to the cancellation of terms in the integrals. The conversation also addresses a related problem involving odd functions of k, reinforcing the idea that the arguments for both problems are valid. Ultimately, the participants reach a consensus on the importance of Lorentz invariance in the context of the integrals.
eudo
Show that
[\hat{\phi}(x_1),\hat{\phi}^\dagger(x_2)] = 0
for (x_1 - x_2)^2 &lt; 0
where \phi is a complex scalar field
\hat{\phi}=\int\frac{d^3 \mathbf{k}}{(2\pi)^3 \sqrt{2\omega}}[\hat{a}(k)e^{-ik\cdot x} + b^\dagger(k)e^{ik\cdot x}]
with
[\hat{a}(k),\hat{a}^\dagger(k&#039;)]=(2\pi)^3\delta^3(\mathbf{k}-\mathbf{k&#039;})
[\hat{b}(k),\hat{b}^\dagger(k&#039;)]=(2\pi)^3\delta^3(\mathbf{k}-\mathbf{k&#039;})
and all other commutation relations vanish.
This is problem (7.3) in Aitchison and Hey's QFT book. I have a couple questions about the solutions that are posted online here. They get eventually to the difference of two integrals:
\int\frac{d^3\mathbf{k}}{(2\pi)^3 2\omega}e^{-ik\cdot (x_1-x_2)}-\int\frac{d^3\mathbf{k}}{(2\pi)^3 2\omega}e^{ik\cdot (x_1-x_2)}
So far so good. Then they argue that for space-like intervals, x1-x2 can be transformed to -(x1-x2) by a Lorentz transformation, and thus the second term cancels the first.
Now, I agree that each of the integrals must be Lorentz invariant, so you are allowed to evaluate each one in whichever frame you want, but I don't see how one is allowed to transform just the x1-x2 vector without also transforming the k.
And a related question: In a different problem (5.6), when we come to a similar integral, they suggest transforming to a frame where t1=t2, and since the resulting integral is an odd function of k, it must be zero. And since it's Lorentz invariant, it must be zero for all space-like intervals. It seems to me that this argument works for this problem, too, so I'm not sure why they bring up this other argument about transforming x1-x2 to -(x1-x2).
Anyone want to help explain what I'm missing?
Thanks
You are integrating over \vec{k}. Thanks to the invariance of \mathrm{d}^3 \vec{k}/\omega where \omega=\sqrt{m^2+\vec{k}^2} you know that the result is a Lorentz scalar F(x_1-x_2). That means that under Lorentz transformations
F&#039;(x&#039;)=F(x)=F(\Lambda^{-1} x).
Thus you only need to transform x=x_1-x_2.
It's only crucial to show that for a spacelike x you can always find a Lorentz transformation such that \Lambda x=-x. Since you can orient your coordinate system always such that x=(0,\xi,0,0) you just need to find a Lorentz transformation which makes out of this \Lambda x=(0,-\xi,0,0).
Likes 1 person
Thanks for the reply. I guess I'm missing the last part of that equality F(x) = F(\Lambda^{-1}x). As a test, if I define a function
F(x)=k\cdot x
where k is some arbitrary 4-vector, then F(x) is a Lorentz scalar. If I have some transformation such that x&#039;=\Lambda x, then
F&#039;(x&#039;)=k&#039;\cdot x&#039;=k\cdot x=F(x)\not=F(\Lambda^{-1} x)
I understand that in the original problem we're integrating over \vec{k}, but it still seems to me we need to transform the \vec{k}.
Argh. That's of course a typo. The correct rule is
F&#039;(x&#039;)=F(x)=F(\Lambda^{-1} x&#039;),
because
x&#039;=\Lambda x \; \Leftrightarrow \; x=\Lambda^{-1} x.
Right after I posted that, I figured that's what you meant. And it finally struck me why we don't have to worry about the \vec{k}. Thanks for your help.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
