Is energy conservation violated under gravity?
The discussion centers on the conservation of energy in the context of gravitational forces. It explores whether energy conservation is violated as an object moves away from Earth, questioning the behavior of kinetic and potential energy at infinity. Participants clarify that while gravitational potential energy increases as an object moves away, kinetic energy decreases, maintaining the overall energy balance. The concept of negative work done by gravity is emphasized, indicating that potential energy can be viewed as the work done on an object. Ultimately, the conversation highlights the importance of understanding energy transformations under gravitational influence without violating conservation principles.
hav0c
Loss of energy under gravity??
(i am ignoring all forces except gravity)
by conservation of energy-at any 2 points in time the sum of Ekinetic and Epotential is the same.
at infinity
Epotential is nearly zero, Ekinetic is also nearing zero(or is it)??
then am i flawed in my above statement or is energy conservation violated??
here gravity is doing negative work on the object so both kinetic and potential energies are going down
how so?
at infinity
Why would you think that the kinetic energy is necessarily zero at infinity? (Assuming it had enough energy to keep going. Depending on the initial KE, it may just reach a maximum distance.)
how so?
As the object gets further away from earth, gravity does negative work. But that means the potential energy increases as the kinetic energy decreases.
thank you
i suddenly realized
why would potential energy increase as it gets further away from the Earth's surface?
it is=mgh
as the value of h increases g decreases
EDIT: contradicting my above statement potential energy can be thought of -(the work done on an object)
please clarify
hav0c said:
i suddenly realized
it is=mgh
For distances close to the Earth's surface the potential energy is mgh. So even though g does decrease with distance, as long as you are getting further from the surface gravitational PE is increasing.
please clarify
It's certainly true that gravitational PE is the negative of the work done by gravity. Since the work done by gravity is itself negative as an object is raised, the change in gravitational PE will be positive.
Start at the Earth's surface, with a pretty low value of Potential (a large negative number for an attractive field). You go upwards with some KE (always positive because v squared is positive) and the KE decreases as your PE increases (from very negative to not so negative). If you have enough KE, to start with, by the time you get to 'infinity' you will still have some left and you 'escape' with some KE to spare. If not, your KE will get to zero before the PE reaches zero and you will fall back.
It's all in the signs.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
