Love-joy Jaw-in-Shear couplings
  • Thread starter Thread starter EspElement
The discussion focuses on the challenges of using Love-joy Jaw-in-Shear couplings for an application requiring frequent shaft removal and replacement. The user seeks a coupling that can handle a minimum torque of 7260 in/lb and is particularly interested in the LS225 model. Key concerns include ensuring proper shaft alignment to prevent coupling damage and the ease of interchangeability, especially since the coupling may need to be replaced 20-30 times daily. Recommendations include consulting with a manufacturer's representative for insights and potential support. Overall, the emphasis is on finding a solution that facilitates quick and accurate coupling changes without extensive setup.
EspElement
Hello guys, I am relatively new here. I hope to spend more time here helping and receiving advice more often. Currently i have some questions with Love-joy couplings.
I have an application where i need to remove a shaft and replace it on the fly with ease. I looked for all kinds of couplings/designs of couplings to make this easiest for my customer. I need a coupling that handles a min of 7260 in/lb of torque. This being the max output of my gear box i am using to drive it. I am interested in the LS225. Below is a link to the page.
http://www.lovejoy-inc.com/products/jaw-in-shear-couplings.aspx
Does anyone have experience with these couplings? Are they easy to interchange? Does it require a large amount of setup to replace them?
I'm hoping this is the easiest and most positive solution for my customers application.
If anyone has ideas or thoughts they are welcome here. I am open to suggestions and to discuss the design.
Attached is a picture of my application.
Thank you all!
No one seems to have any thoughts on this?
Regards
Josh
I've not used this particular one, but I've used couplings by Lovejoy and Falk, all of which were fairly easy to use. I think the primary concern in any application is to ensure the alignment of the shafts is within the acceptable tolerance limit of the coupling. Every coupling has to have the shafts within a certain angular and linear misalignment or the coupling will be damaged over time and fail. Also verify RPM and torque is below the limit for the coupling you select.
To get a better feel for the coupling, you should discuss your application directly with a manufacturer's representative. They might also give you one or loan you one to play with.
I am working on this individually so its not a work related item. So i wouldn't get the support i would if I had a company with more order opportunities. I noticed i have been having a lot of troubles with vendors for that reason.
I like to use my vendors to help me with my designs in that case but this time I am not going to get a whole lot of support.
The max RPM will be around 10. It will certainly be a very slow application.
They recommend the load rating is 1.1 (16 hrs a day) times the calculated actual. This application is not going to be ran near 16 hours but i didn't like the recommended 1.0 for 8 hrs. The output torque I show above is the highest output by my selected reducer. So i should be okay with a 1.16 SF on that.
The angular allowance is up to ± 2°. That seems like a high tolerance for this application.
As you said, the main concern is changing this out maybe 20-30 times a day and getting it aligned properly. Is there any suggestions on ensuring this? or any ideas for the setup to make this easy?
Thanks for the reply
Regards
Wow! You're having to remove/reinstall this coupling 20 to 30 times a day? Is that what the issue is? Are there any other parts being removed/reinstalled like that? I think if that's the case, the parts have to be aligned when they're installed so that there's no need to make any adjustments. Just slap together and go. That said, I wonder if there isn't a better way to do this because pulling it out and reinstalling that often would take a lot of time that a customer of the product might not want to invest. So bottom line, is there a way to make this easier for the operator to reinstall? I don't know what your system looks like so I really can't make any suggestions.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
10K
