Low Viscosity Oil, Tanks, Pressure Relief Valves and Check Valves
The proposed hydraulic system for a food business involves multiple tanks, pressure relief valves, and check valves to facilitate liquid recirculation at 2,250 PSI. Concerns were raised about the potential for contamination and the need for rigorous cleaning protocols, as well as the risks associated with high-pressure oil, including worker safety and fire hazards. The importance of ensuring that all components are food-grade and the necessity of proper disposal methods for contaminated oil were emphasized. Suggestions included considering constant flow or pressure pumps to simplify the design. Overall, the system requires careful consideration of hygiene, safety, and functionality to be viable.
Findustry Corp
TL;DR Summary
I have an idea for a system to build into a food business I'm starting, but I'm no physicist. I need advice on flow of a pressurised system.
Hi Whoever,
I have an idea for a system which would work for my food business but it doesn't exist. The system essentially relies on hydraulics, pressure relief valves and check valves for recirculation upon reached pressure.
All tanks/pipes (The entire system) will be prefilled except for 1 (Number 3). All check valves must only let liquid pass through in one direction and withstand 2,250 PSI. All pressure relief valves must release pressure by expelling liquid via a small aperture when 2,250 PSI is reached.
Tank number 1 will be the main storage tank for the system, this is top fed into via Check Valve 1 to stop back flow and then with an exit route at the bottom, this exit feed will lead into Tank Number 2 via Pressure Relief Valve 1 that expels a short burst of liquid when it reaches 2,250 PSI.
This then enters the top of Tank Number 2, which continues to fill up until 2,250 PSI is reached (Will Pressure Relief Valve 1 also stop backflow? Or will I need to integrate a check valve?). Once 2,250 PSI is reached, Pressure Relief Valve 2, at the bottom of Tank Number 2 will release the same burst of liquid as previous into the Tank Number 3.
Tank Number 3 has a base conical which will have an electrically powered by pump at the base to constantly pull through any liquid that gathers. This pump will pump the liquid through Check Valve 2 into Tank Number 4. This tank will have other mechanics for the systems purpose, which I have external instructions for.
As the liquid enters Tank Number 4 the check valve again prevents back flow, once Tank Number 4 reaches 2,250 PSI, Pressure Relief Valve 3 will then release the same burst of liquid into Pre Filled Pipe 1.
Pre Filled Pipe 1 feeds back into Tank Number 1 via Check Valve 1. The idea is that due to laws and rules of a hydraulic system that this will just keep pushing everything through and recirculate the liquid until I'm finished for the day.
What's wrong with my idea? There's gotta be a lot!
I've got brains and I'm not a stupid person, but I am an arts student. My Science education doesn't go past GCSE (Triple A's) but this was a few years ago and Physics always baffled me. If you have any insight I would love to hear it.
Thank you for your time,
Fin
Welcome to PF.
Can you upload a diagram of your hydraulic system? Use the "Attach files" link below the Edit window to upload a PDF or JPEG version of your system diagram.
Can you say more about what all of these hydraulics are supposed to be doing? I don't see any mention of food so far in your description...
Typical hydraulic system diagram:
https://crossmfg.com/resources/technical-and-terminology/basic-hydraulic-theory
What is the volumetric capacity of the tanks?
There are things that will grow in the system. You will need to clean and sterilise the system at the end of each day. A non-return valve is a reservoir for infection. Valves are very difficult to clean. For example, the salmonella that infect peanut crushing machines, then kill people, force product recalls, and the insurance pays-out-big, in class-action compensation. There will need to be rigorous product testing.
How will the contaminated hydraulic food-grade oil be recycled, or disposed of ?
A pinhole leak at 2000 psi will inject oil under the skin of any worker nearby, that poses a risk of traumatic amputation and/or gangrene. You will need solid steel screens for worker protection. A high pressure oil mist is a fire hazard.
Your description 'smells' like it could become a rancid and sticky, oil-seed extraction plant. Try to avoid that.
Constant flow, or constant pressure pumps, may simplify the design.
Likes berkeman and Lnewqban
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
