Low volumetric flow rate measurement
Measuring fluid resistance through ductwork at low volumetric flow rates presents challenges, as the resistance does not remain constant despite CFD analysis suggesting it should. The intern's machine accurately measures pressure drops but struggles to provide consistent readings at flow rates of 10 CFM or lower, likely due to instrument error and the resolution limits of pressure taps. The setup includes a plenum designed to isolate the duct, yet the results still do not align with CFD predictions. The discussion highlights the importance of understanding minor and major losses in the system, as well as the potential impact of entrance effects on measurements. Accurate low flow rate measurements remain elusive, necessitating further investigation into how CFD programs determine resistance values.
wrath90210
Hi everyone, I'm currently a mechanical engineer interning at an HVAC company. I need to measure the resistance of a fluid through ductwork. The CFD shows a linear curve through a plenum when plotting R vs volumetric flow rate. For example, a straight rectangular box 1 1/16” by 2.5” and 3ft long has air passes through it. The machine I use can measure pressure drops at different spots by knowing the input pressure first. Then measuring the second pressure it computes the flow rate. It also takes density and air temperature into consideration.
When running tests of 10 cubic feet per minute or lower the resistance is not constant. The CFD analysis we run shows a constant resistance value that converges. The problem is measuring this in the real world and matching it up to the CFD. Of course the CFD could be incorrect, but the problem has been known for some time.
The resistance is given by R=(DeltaP)/(volumetric flowrate^2)
When plotting 10CFM to 1CFM and calculating each resistance the curve is not a constant value as it should be. The error is the measuring equipment. At HIGH volume flowrates there is no problem, but still does occur when measuring many twists and turns through a pipe.
CMM is cubic m^3/min
as CFM is ft^3/min
Curves and data
P3 and P4 are two pressure taps. They are each a delta in pressure. Just two different locations on the plenum.
I am also aware of minor losses and major losses and the math I have done is accurate to what the machine finds.
Any ideas how to help the R vs CMM curve match the CFD of my system? I just cannot get accurate measurements at low flow rates.
Thank you all!
Bump...
I have made a large box (plenum) that I place the duct inside. The outside of the duct is exposed to atm, while the other side is inside the box. The box is airtight. I then know the flowrate into the box and know the P inside the box. So the R value can be obtained. But I still have the same result. Evern trying to remove entrance effects seems hopeless. Does anyone know how CFD programs find R values in flows?
Without understanding the setup better, I can at least tell you that perhaps, at lower flow rates, your delta P approaches the resolution of your pressure taps, making it difficult to distinguish the actual measurement from the instrument error. You can average the delta P over time, but if the delta P is on the order of the instrument error, you are unlikely to get a good measurement regardless.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
