Lowest Resonant Frequency Issues
The discussion focuses on calculating the lowest resonant frequency of a string with a given length, mass, and tension. The wave speed for the string is correctly determined to be 41.9 m/s. The participant struggles with the resonant frequency calculation, repeatedly arriving at an answer of 30.4 Hz, which is deemed incorrect. They express frustration over the consistent error despite using various equations related to frequency and wave properties. The thread highlights the challenges of applying theoretical equations to practical problems in wave mechanics.
Hypnos_16
A 138 cm length of string has a mass of 4.98 g. It is stretched with a tension of 6.35 N between fixed supports. What is the wave speed for this string?
What is the lowest resonant frequency of that wave?
(wavelength) = 138cm = 1.38m
M = 4.98g = 0.00498kg
Ft = 6.35N
v = 41.9m/s
(It's a two part question, i already know the speed is right, it's the second half I'm having trouble with)
I've tried all the equations i can think of that have ƒ in them
(Wavelength) = (1 / ƒ) * ( √(T / µ))
V = (Wavelength) / T
ƒ = 1 / T
(Wavelength) = (1 / ƒ) * (√ T / µ)
(Wavelength) = (1 / ƒ) * (v)
(Wavelength) = (1 / ƒ) * (41.9)
(1.38)(41.9) = (1 / ƒ)
(0.0329) = (1 / ƒ)
ƒ = 30.4Hz
that's always the answer i get no matter what i try, and it's always wrong.
What's going on?
do you play a string instrument such as guitar or violin?
No, no i do not.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
