Lowpass Butterworth & Bandpass Filters
  • Thread starter Thread starter asdf26asdf26
    Filters
The discussion focuses on finding proofs for the Butterworth lowpass and bandpass filters. The user seeks specific equations for the Butterworth filter, Vo/Vin = 1 / [1 + (f/fc)^4]^(1/2), and for the bandpass filter, Vo/Vin = 1/[1 + {[(w^2) / (wo^2)] - 1} / wRC]. While the user has made progress on the bandpass filter using an RLC circuit, they are still working on the Butterworth filter proof. Participants suggest showing previous work and drawing circuit diagrams to aid in solving the problem. The conversation emphasizes the importance of understanding the underlying concepts and equations for filter design.
asdf26asdf26
Please help me find proofs of the Butterworth lowpass filter and the bandpass filter.
for the butterworth. i need to prove (Vo/Vin) = 1 / [1 + (f/fc)^4]^(1/2)
for the bandpass: (Vo/Vin) = 1/[1 + {[(w^2) / (wo^2)] - 1} / wRC]
my professor said these proofs were on the internet, but i can't find anything useful.
any help would be greatly appreciated. thanks.
Homework problems should be posted in the Homework Forums. This thread will hopefully get moved there.
You need to show us what you have done to try to solve the problem, and then we can try to help you. Do you know how to draw a first order Butterworth lowpass filter? How about a second order? Draw the circuit, and write the differential equation for Vo/Vi. Then solve it to see if you get the equations above.
Sorry I didn't know there was a Homework section. This isn't really homework anyway. its just lab knowledge, but whatever, sorry about that.
I figured out the bandpass filter and am still working on the Butterworth.
For the bandpass i looked at a RLC crkt and set
Vo = (R / [jwL + (1/jwL) + R]) Vin
... work ...
then i just used algebraic manipulation and substitution and finally got to
Vo/Vin = 1 / sqrt{[(wRC)^2 / (wRC)^2] + ((w^2 LC - 1)^2) / (wRC)^2}
where LC = 1/wo^2
it looks so confusing typed out like shown above. it looks much better in Equation Editor.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
