Lucas-Lehmer Test With Polynomials
  • Thread starter Thread starter Milkman
    Polynomials Test
Milkman
Does anyone know why the lucas-lehmer test won't work with numbers represented by polynomials? The modulus polynomial does not divide the last term correctly for some reason.
Example (the code boxes are polynomial long division):
the numbers will be represented in base 4, so 4 = x
p = x + 1 (or 5; the mersenne exponent)
2^p-1 = x^2 + 3x + 3 (or 31; the mersenne number to be tested)
p-2 iterations of the lucas sequence, mod 2^p-1:
(x)^2 - 2 = x^2 - 2
x^2 - 2 = -3x - 5 (mod x^2 + 3x + 3)
Code:
x^2 + 3x + 3 ) x^2 + 0x - 2
              -x^2 - 3x - 3
                    -3x - 5
(-3x - 5)^2 - 2 = 9x^2 + 30x + 23
9x^2 + 30x + 23 = 3x - 4 (mod x^2 + 3x + 3)
Code:
x^2 + 3x + 3 ) 9x^2 + 30x + 23
              -9x^2 - 27x - 27
                       3x - 4
(3x - 4)^2 - 2 = 9x^2 - 24x + 14
9x^2 - 24x + 14 = -51x - 13 (mod x^2 + 3x + 3)
Code:
x^2 + 3x + 3 ) 9x^2 - 24x + 14
              -9x^2 - 27x - 27
                     -51x - 13
x^2 + 3x + 3 should divide 9x^2 - 24x + 14 evenly, and the last result should be 0, not -51x - 13. And -51x - 13 is not congruent to zero in any field (I don't think).
So what's wrong?
Don't we should have all coefficients lower than x=4 ?
As an example, 3x - 4 = 2x ?
T.
That's not what Lucas-Lehmer says: it says that
4² + 3*4 + 3
should divide
9*4² - 24*4 + 14
evenly. (And it does)
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
