Maclaurin Series f(x) = (2x)/(1+x2)
The discussion revolves around finding the Maclaurin series for the function f(x) = (2x)/(1+x^2). Participants are exploring various methods to derive the series, including calculating derivatives and considering alternative approaches.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the challenges of calculating derivatives, noting that they lead to lengthy expressions and zeros at x=0. Some consider using the geometric series formula to simplify the process, while others express concerns about the appropriateness of this method.
The conversation includes various attempts to understand the coefficients in the series and how they relate to derivatives at zero. Some participants are questioning how to extract coefficients from the series and what they imply about the derivatives, indicating a productive exploration of the topic.
There is mention of a previous exam question that involved finding a specific derivative, which adds a layer of complexity to the current problem. Participants also reference homework constraints and the potential for simpler methods, such as polynomial long division, to achieve the desired series.
jacoleen
Write the Machlaurin series for :
f(x) = (2x)/(1+x2)
I tried finding all the derivatives (aka f(x), f'(x), f''(x), etc..) but the equations started getting longer and longer and would always result in 0 when x=0. This was on a final exam last year, and I don't think they would have made students do long computations like that
Also, I tried just finding the derivatives for (1-x)-1, but again, I ended up with a bunch of zeros
Help?
Hmmm... I'm not sure, but would it be cheating to use that
[tex]1 + r + r^2 + r^3 + \cdots = \frac{1}{1-r}[/tex]
for [tex]|r| < 1[/tex]?
If you do that, you wouldn't need any calculus at all (except for the uniqueness of Maclaurin series).
I was thinking of doing that in the first place, but on another exam there was a similar question and part c was Find f^2007(0) :(
In that case, you can work backwards, because the coefficient of xn in the series gives you [tex]\frac{f^{n}(0)}{n!}[/tex]
so my series would just be: Summation of [(-1)n2x2n+1]?
I'm not sure how I would work backwards though :|
Usually, you would compute [tex]\frac{f^{2007}(0)}{2007!}[/tex] to find the coefficient of x2007 in a Maclaurin series. But in this case, you know the coefficient. What does that tell you about [tex]\frac{f^{2007}(0)}{2007!}[/tex] ?
I'm really not getting it..
do i isolate for f(2007) by equating it to the summation? (without the summation term in front)
You're on the right track. What is the coefficient of x2007 in this problem?
the summation divided by x^-2007?
* without the negative
Actually, you found that
[tex]\frac{2x}{1+x^2} = \sum_{n=0}^{\infty}(-1)^n2x^{2n+1}[/tex]
When you write out the summation, you get
[tex]\frac{2x}{1+x^2} = 2 x-2 x^3+2 x^5-2 x^7+2 x^9-2 x^{11} + \cdots[/tex]
From this, can you find the coefficient of x2007?
is it just -2?
(i'm so sorry I logged off btw, my computer overheat :(
Yep!
Now remember that the Maclaurin series of f(x) can be found by:
[tex]f(x) = \frac{f(0)}{0!} + \frac{f'(0)}{1!} x + \frac{f''(0)}{2!} x^2 + \frac{f'''(0)}{3!} x^3 +\cdots[/tex]
So the coefficient of x2007 must be
But you know that the coefficient is -2. So what does this tell you about f2007(0)?
it's equalled to 2?..and so f(2007) = 2*2007!?
Close! It's actually f(2007)(0) = -2 * 2007!, but I think you got the idea. ;)
OMG..it actually makes sense!
Thank you so much for your help! :D
f(x) = (2x)/(1+x2)
Help?
If all you need to do is get the Maclaurin series for 2x/(1 + x^2), there's something you can do that's much simpler than what I've seen in this thread - just polynomial long division to divide 2x by 1 + x^2. Doing this, I get 2x - 2x^3 + 2x^5 -...
  • · Replies 48 ·
  • · Replies 16 ·
  • · Replies 16 ·
