Mag induction to power IR transmitter pulse
The discussion revolves around designing a circuit that uses magnetic induction to power an IR transmitter for measuring wheel speed without batteries. A simple 555-based transmitter and a 38KHz receiver are proposed, but concerns arise about energy storage and triggering the pulse effectively with varying wheel speeds. The challenge lies in ensuring sufficient energy is stored in a capacitor to transmit data reliably, especially at slow or fast wheel rotations. Alternatives like using a direct power source from the wheel or powering the LED directly from the induction coil are suggested, although these come with potential complications. Overall, achieving a reliable system may require careful consideration of energy management and signal modulation.
bewert
I'm trying to design a simple circuit that will enable a magnet passing by an induction coil to send an IR pulse to a simple receiver plugged into a Linux box. This will be used to measure the speed of a turning wheel without having to worry about batteries or a power block of any sort. Any ideas?
I have the design of a simple 555-based transmitter and a simple 38KHz receiver, all using parts from Radio Shack. My concern is powering up the capacitor and triggering the pulse with magnetic induction from a magnet attached to the wheel. Very much like a bicycle speedometer, where the magnet passes a reed switch to close a circuit, I want the magnet to pass by an induction coil to transmit an IR pulse.
What you seem to be talking about at this point is designing a generator.
Probably doable if the wheel has a useful minimum/maximum rotation rate.
Very difficult if the wheel is going to turn slowly as the power will be limited.
Also difficult if the wheel turns fast, because there will not be enough time to transmit a complete data word before the next one comes due.
First the pulse will have to store enough energy in a capacitor to run your transmitter circuit long enough to transmit the data pulse.
You will also need some sort of voltage regulator or switching power supply circuit to get the voltage correct for the transmitter circuit.
It will be a lot simpler to use a battery or power the circuit from whatever power source is turning the wheel directly, rather than building what is effectively a brake that will try to stop the wheel.
You could also try powering the led directly from the coil, but that could lead to issues with other IR sources in the room.
This is why remote controls use a 38Khz modulated carrier with several repetitions of the data word.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
