Mag of impulse required to change speed question.
The discussion centers on calculating the impulse required to increase the speed of a proton from 0.995c to 0.998c, where c represents the speed of light. The participant initially attempted to use the equation for momentum, applying the formula (momentum_final) = (momentum_initial) + F_net * (change in time) to derive impulse. However, they recognized that traditional momentum calculations (mv) are inadequate at relativistic speeds, necessitating the use of relativistic momentum equations to achieve accurate results.
  • Understanding of relativistic physics concepts
  • Familiarity with momentum and impulse equations
  • Knowledge of the speed of light (c) and its implications in physics
  • Basic algebraic manipulation skills for solving equations
  • Study the concept of relativistic momentum and its equations
  • Learn how to apply the Lorentz factor in calculations involving speeds close to the speed of light
  • Explore the relationship between force, impulse, and time in relativistic contexts
  • Review examples of impulse calculations in high-speed particle physics
Physics students, educators, and anyone interested in advanced mechanics, particularly those focusing on relativistic effects in particle motion.
Coletrain12
A proton has mass 1.7x10-27 kg. What is the magnitude of the impulse required in the direction of motion to increase its speed from 0.995c to 0.998c? Where c is the speed of light.
Im not quite sure of what equation is supposed to be used. I tried using (momentumfinal)=(momentuminitial) + Fnet*(changeintime)
Ok my attempt at the problem is the only way i can think of it and the answer is still wrong. I first multiplied the speeds by the mass to get a momentum. Then used the two momentums and plugged them into the equation above and solved for Fnet*(changintime) which equals Impulse if I am not mistaken. I got the number 1.53e-21 for my answer.
The only problems i can think of is maybe those speeds are speeds(needs to be velocity).. and can't multiply by the mass to get a momentum but i don't see why that would cause a problem. Overall I am stumped on this problem and not sure why what I've done doesn't work. I even have talked to others in the class and no one can figure it out.
Thanks for all the help in advance guys.
Considering how high the speed of the particle is, I wonder if you have to consider relativistic momentum?
Yes, 0.995c is definitely relativistic. mv will not work for calculating momentum.
  • · Replies 19 ·
  • · Replies 24 ·
