Is the Correct Option for Magnetic Field Homework Statement (d)?
Pushoam
Using ## \nabla \times \vec A = \vec B##. I got that both ##\v A_1 ~~and~~ \vec A_2 ## produce ## \vec B##. So, the correct option is (d).
Is this correct?
[/B]
Yes.
Thanks.
