Magnetic field of a moving charge
To calculate the magnetic field produced by a moving negative charge, the equation B = μ0/4π * (q(v x r))/r² is used, where r is the position vector from the charge to the point of interest. The user initially attempts to compute the magnetic field components separately but is advised against this approach due to the nature of vector operations. It is emphasized that the cross product must be evaluated for the velocity and position vectors together to obtain the correct magnetic field. Understanding how to compute the cross product of two vectors is crucial for solving the problem accurately. The discussion highlights the importance of using vector equations rather than treating components independently.
squeak
A negative charge q = −3.20×10-6C is located at the origin and has velocity υ⃗ =(7.50×104m/s)ι^+((−4.90)×104m/s)j^.
At this instant what is the magnetic field produced by this charge at the point x = 0.230 m , y = -0.300 m , z= 0? Give the x, y and x components
B = u0/4π. (qv x r)/r2
So to find Bx I've tried using r = 0.230 and v = 7.5x104 giving 10-7 x 3.2 x 10-6 x 7.5 x 104/0.2302. However i have a feeling I can't just take the x/y components individually. I know that a cross product goes to 1 if the components are perpendicular and 0 if they are parallel and feel like this will help but i just can't put it all together to give me the correct answer. any hints would be very much appreciated!
You are correct - you cannot just take the components individually like that. You have a vector equation, why not use it?
Do you know how to evaluate a cross product between two arbitrary vectors?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
