Magnetic field of helmoholtz apparatus
The user is attempting to calculate the magnetic field of a Helmholtz apparatus using the formula B = 0.7155NI/R. With values of N=130, I=1.82, and R=0.15m, the calculated magnetic field is 1128.6, which is considered excessively high. There is a request for assistance in identifying potential errors in the calculation. Clarification is sought regarding the units used in the formula, with a reference to the SI units for the Helmholtz coil provided. Accurate unit conversion and verification of the formula's parameters are essential for correct results.
noname1
I am trying to calculate the magnetic field of an experiment with the apparatus but my values are way too high and i can't figure out what i am doing wrong
I am using the formula B = 0.7155NI/R
N= 130
I=1.82
R=15cm=.15m
calculating this i get 1128.6 which is too much of a value for the magnetic field, any help would be appreciated
What units are your equation in? Look here for the formula in SI units
http://en.wikipedia.org/wiki/Helmholtz_coil"
