Magnetic field for a single-layer solenoid
asdf1
does anybody know why the magnetic field for a single-layer solenoid of a point in the middle of the solenoid axial field is
H=[(4pini)/(10L)]*{[L+2x/[2(D^2+(L+2x)^2]^(0.5) +
[L-2x/[2(D^2+(L-2x)^2]^(0.5)}
where L is the length of a finite solenoid, D is the diameter
You can calculate the on axis magnetic field of a current loop. To obtain the on axis field of a finite solenoid, just integrate.
i did... I'm stuck on where does[(4pini)/(10L)] come from?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
