Solving the Puzzle: How Does the Magnetic Field Affect Balance?
A rectangular coil of wire is used in a balance experiment to explore the effects of a magnetic field on weight. When a magnetic field is activated and a current of 8.50 A flows through the coil, an additional mass must be added to maintain balance. The discussion highlights confusion about the forces acting on the coil, specifically why there is a net downward force despite the presence of an upward force from the magnetic field. It is clarified that the magnetic field may not be uniformly distributed, affecting the forces experienced by the coil. Ultimately, the issue stems from a poorly phrased question rather than a misunderstanding of the underlying physics.
caljuice
Well I have the answer already, just don't understand it.
A rectangular coil of wire is hung from one arm of a balance, as my beautiful diagram will show. With the magnetic turned off, a Mass M is added to the pan on the other arm to balance the weight of the coil. When a constant magnetic field is turn on and there is a currentr of 8.50 A in the coil, how much additional mass m must be added to regain the balance? The magnetic field is also going into the page. Forgot to draw the X's.
Image: http://img262.imageshack.us/img262/6318/balanaceyd8.th.jpg
Because of the magnetic field, the bottom length of the coil exerts a downward force but why is there a net force downwards, causing the torque? Shouldn't the upwards force from the magnetic field at the top of the rectangular coil cancel it out? Thanks in advance.
I agree with you, the upward and downward forces would surely cancel out. Not to say that you diagram isn't excellent, but all I can think is that perhaps there is some small extra detail that we're missing here. Is the magnetic field distributed evenly throughout the entire diagram, for example, or is it localised?
Ah yes. It was only a Mfield around the bottom part, since the question didnt mention that i assumed it was for the whole diagram and they just got lazy. But that makes much more sense, my bad.
Nah, there was nothing wrong with your understanding, you were just faced with a poorly written question.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
