Magnetic flux and how to manipulate it discussion anyone?
The discussion centers on how to manipulate the magnetic flux of a coil, focusing on practical applications and project-specific challenges. Participants explore various methods to enhance magnetic flux, including theoretical and experimental considerations.
  • Homework-related
  • The original poster (OP) seeks assistance in manipulating magnetic flux for a project involving a 3-foot diameter coil, aiming to fill the inner area with a magnetic field and project it 12 inches away.
  • Some participants suggest increasing the number of turns in the coil, increasing current, or changing the coil's shape as potential methods to manipulate magnetic flux.
  • One participant mentions using ferrous metal shapes to guide the magnetic flux and references Helmholtz coils as a means to achieve a more uniform magnetic field.
  • Another participant questions whether the OP is constructing a solenoid and if the inquiry pertains to increasing the magnetic field produced by it.
  • The OP expresses uncertainty about the applicability of Helmholtz coils for their specific needs, particularly regarding the distance between coils.
  • Participants discuss the use of probes to measure magnetic field strength, particularly in the context of AC versus DC magnetic fields.
There is no consensus on the best approach to manipulate the magnetic flux, with multiple competing views and suggestions presented throughout the discussion.
The discussion includes various assumptions about the project requirements and the effectiveness of different methods, which remain unresolved. The OP's lack of mathematical skills is noted as a limitation in determining specific parameters for their project.
NMNXX
Good day all, I am looking to discuss how to manipulate the magnetic flux of a coil. I unfortunately lack the math skills to calculate what I actually need to build for my project. I have been coop up in my garage trying to physically solve the problem but I am running out of time and money for materials and I know that the answer is in the math. Any help would be greatly appreciated.
What manipulations do you want to do?
What is your project?
The OP is indeed very vaguely worded, but I'll throw this Wiki article out there nonetheless:
https://en.m.wikipedia.org/wiki/Magnetic_circuit
These "circuits" (in analogy to electric circuits) are all about the manipulation of the magnetic flux.
Thank you for the interest.Project: I am currently trying to produce more magnetic flux through a coil. I have a round 3 foot diameter coil that I am trying to fill the entire inner area of the coil with a magnetic field and also project field a distance of 12 inches from the coil. Manipulation: I would like to manipulate the field in two ways. 1. Project the field a greater distance from the coil. 2. Fill entire area with field. Please correct me if I am wrong but my understanding is that I can do 3 things to increase or manipulate the magnetic flux. 1. increase number of turns in coil. 2. increase charge or current. 3. Increase or change shape of coil. Any help or advice would be appreciated. Thank you
Thank you for the article. I apologize for the vagueness.
You can also use ferrous metal shapes to guide the flux.
Have you read about Helmholtz coils? That is a way to help you make the flux more uniform in the volume between the two coils...
https://en.wikipedia.org/wiki/Helmholtz_coil
This is very confusing, due to the terminology being used (or misused).
Are you making a solenoid? And are you asking how to increase the magnetic field produced by this solenoid?
Zz.
Thank you for the reply, I have been looking at the Helmoltz coil but have not done decided if it will work for my application. I am afraid I will not be able to reach the distance I need between the two coils. Thanks again
NMNXX said:
Thank you for the interest.Project: I am currently trying to produce more magnetic flux through a coil. I have a round 3 foot diameter coil that I am trying to fill the entire inner area of the coil with a magnetic field and also project field a distance of 12 inches from the coil. Manipulation: I would like to manipulate the field in two ways. 1. Project the field a greater distance from the coil. 2. Fill entire area with field. Please correct me if I am wrong but my understanding is that I can do 3 things to increase or manipulate the magnetic flux. 1. increase number of turns in coil. 2. increase charge or current. 3. Increase or change shape of coil. Any help or advice would be appreciated. I believe this may be the formula I need to use to get the answer I am looking for ( How many turns at what voltage/current do I need for a 3 foot diameter coil to get the distance and coverage of the field I want. Unfortunately I can not do this math. Formula at 5:27
Are you working with DC magnetic fields or 60Hz AC magnetic fields? If AC, you can buy inexpensive probes that plug into your DVM to let you know what your field strength is through the coil and surrounding area. Here is one that I've used in the past:
http://custommagneticshielding.magn...egories/evaluation-kits-meters-probes/ep-101a
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 43 ·
  • · Replies 194 ·
23K
