Magnetic Flux of Earth onto myself
The discussion revolves around estimating the magnetic flux through a person's body due to the Earth's magnetic field when facing North and the change in flux when turning to face South. Participants clarify that the problem is conceptual, relating to magnetic flux calculations similar to electric flux. It is suggested that the magnetic flux can be calculated using the equation Φ = B * A, where B is the magnetic field strength and A is the surface area of the body. The importance of considering the body's surface area rather than the Earth's is emphasized, as the flux is specific to the area and field strength. Overall, the conversation aims to guide the original poster in understanding the conceptual approach to the problem.
carrotcake10
Estimate the magnetic flux (due to the Earth's field) through your body (back to front) if you stand facing North. What will be the net change in flux if you turn and face South?
Gauss's Law and variants
\oint E\bullet dA
In the past, for simple problems we would always just basically do Qenclosed/Epsilon0.
But to be honest, I don't know where to head in this case.
This problem is suppose to be more conceptual than an actual answer, but I'm missing something apparently.
If someone could point me in the right direction it would be greatly appreciated.
\oint E\bullet dA
I think it is pretty musc the same as your electirc flux questions.
\int B\bullet dA =\phi_{m}
Since you will be orthogonal to the B field, and the B field is constant the integral becomes trivial, and is just your bodies surface area. Provided your at the equator.
Good point about where I am standing. I guess my prof overlooked that part of the question. But let's assume I am at the equator. Would I be using the equation B * A? B being the force of the Earth's magnetic field, and A being my body's surface area?
Yes, I think so. You can probably assume also that your are two-dimaensional (ie no depth) or treat yourself like a uniform cylinder.
Just a quick clarification, sorry. Would I be using the surface area of my body, or the surface area of the earth? I would almost think the surface area of my body would be negligible.
The question asks for the flux through your body, so it would be silly not to use that. Your right, compared to the size of the Earth you are tiny, but that is irrelevant here. Flux is relative to the area and the field strength, nothing else matters. Hope this helps (Sorry, I'm in the UK and it is getting late here, so I'm a bit tired).
Sure does, thanks for all your help.
