Understanding Magnetic Flux: Visualization & Beyond
Magnetic flux is defined as the total number of magnetic field lines passing through a specified surface area. It can be visualized similarly to electric flux, where the magnetic field replaces the electric field. To calculate magnetic flux, one must consider the dot product of the magnetic field vector B with the surface area vector A, which is normal to the surface. The surface integral is used to sum the magnetic flux across all area elements on the surface. Understanding this concept is crucial for grasping more complex electromagnetic principles.
v_pino
What is the definition of Magnetic Flux?
My textbook tells me that it may be 'visualised as the total number of magnetic field lines rather tan their concentration... be aware that this is NOT a definition.'
thank you
Have you learned what is electric flux yet? If so, magnetic flux is the same as electric flux when you replace the electric field with a magnetic one. But probably you haven't since otherwise you would have understood it easily. Just think of it this way: Suppose you have a magnetic field and you want to know how much of the magnetic field passes through a specified plane surface. Just visualise it as magnetic field lines passing through that plane surface. The magnetic flux would then be the dot product of the magnetic field B with the surface area represented as a vector A normal to the surface. The surface integral is used to represent the summation of all the magnetic flux measured at any area element dA on your surface.
See: http://en.wikipedia.org/wiki/Magnetic_flux
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
