Calculating Maximum Magnetic Force on an Electron in a Television Set
Electrons in a television set are accelerated through a potential difference of 23 kV, which translates to 23,000 volts. The kinetic energy gained by the electrons can be calculated using the formula KE = qV, where q is the charge of the electron. To find the velocity, the kinetic energy can also be expressed as KE = (1/2)mv^2, allowing for the two equations to be equated. The charge of the electron in coulombs is necessary to convert the potential difference into energy. This process ensures that the units align correctly for calculating the maximum magnetic force using F = qvB.
buckeyes
In a television set, electrons are accelerated from rest through a potential difference of 23 kV. The electrons then pass through a 0.28 T magnetic field that deflects them to the appropriate spot on the screen. Find the magnitude of the maximum magnetic force that an electron can experience.
i know to use F=qvB to find max but i am having trouble getting the right units to find v i use (1/2)mv(sq.). but how do i get 23kV in the right units to use this equation?
An electron passing through a potential difference of V volts gains an energy of q*V where q is the electron charge. So that's it's kinetic energy KE=(1/2)mv^2 (where v here is velocity). Equate the two energies and find the velocity.
do i use 23kV or do i need to convert that unit?
23kV=23000V. Just multiply that by the charge in (in coulombs) of an electron. Volts are measured in joules per coulomb. See? The units will come out just right.
