Calculating Magnetic Force on a Wire in a Uniform Magnetic Field
To calculate the magnetic force on a wire in a uniform magnetic field, the wire's length, current, and the angle between the wire and the magnetic field are crucial. In this case, the wire is 0.25 m long, carries a current of 4.0 A, and is in a 0.50 T magnetic field at a 45-degree angle. The confusion arises regarding the angle's reference; clarifying that the angle is between the wire and the magnetic field is essential for the calculation. The formula to determine the force involves using the component of the magnetic field that is perpendicular to the current, specifically B*cos(45). Understanding these parameters is key to solving the problem accurately.
Suy
What is the magnetic force on a wire 0.25 m long, carrying a current of 4.0 A, when placed in a uniform magnetic field of 0.50 T, at an angle of 45 to the wire?
this question doesn't make sense to me
it said"when placed", so the wire should be placed in the uniform magnetic field, but at an angle of 45 to the wire,
if it is to the magnetic field, it will make more sense
i am confused...
If the wire is placed so the magnetic field is at 45 degrees to the wire, then the wire is 45 degrees to the magnetic field. Anyway, just B*cos(45) to get the component of the field that is perpendicular to the current.
ty...
