Calculating Angle for Magnetic Force of 2.2F
A charged particle moving at an angle of 19° to a magnetic field experiences a magnetic force F. To find the angle at which it experiences a force of 2.2F while maintaining the same speed, additional information about the particle's initial position and the magnetic field strength is necessary. The discussion highlights that the maximum deflection occurs at right angles to the magnetic source, and the problem is complicated by the lack of details on relative velocities and forces. The inquiry suggests that the question may be poorly worded, as it does not specify the necessary parameters for a definitive solution. Ultimately, the problem revolves around determining the radius from the source where the magnetic field strength yields 2.2F and the corresponding angle change.
buckeyes
When a charged particle moves at an angle of 19° with respect to a magnetic field, it experiences a magnetic force of magnitude F. At what angle (less than 90°) with respect to this field will this particle, moving at the same speed, experience a magnetic force of magnitude 2.2F?
i have no idea where to begin
Not enough information given. Is the particle stationary at start, or in motion? If in motion what is its initial position and vector with respect to the source of the field? It is important because you posit that the solution requires that the particle be moving at the same speed, but do not indicate what that speed is. It looks like (on first blush) that you are looking for a deflection force solution, but without knowing what the source strength is, and the relative velocities are a definitive solution is not easy to express.
i don't know... this is all of the information that the homework problem provides.
OK. Let's take that the question is poorly worded, and work from there. The particle, regardless of velocity, is vectored. If it were not, say it was running directly away from the source, it would slow down, stop, and then fall toward the field. If it was running straight into the source, it would experience an increasing F gradient, but no deflection angle.
The largest deflection in a particle always occurs at right angles between the particle and the source, regardless of relative masses and velocities. (This completely disregards the effect of the forces on the final vecors of the the masses in question, but c'est la vie)
So, if the largest deflection is F at radius 1 (arbitrary, chosen for unit circle and easy lookup in standard tables for cos and sin) is 19 degrees. The question breaks down to this: At what radius from the source (less than 1) does the inverse square law yield a field strength of 2.2. Then, if the particle was at 19 degrees to point 1, what angle is it to point 2?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
