physiksishard
- 2
Can anyone check if I answered these questions correctly? Thanks a bunch!
1. The N pole of a bar magnet is pointed in along the axis of a horizontal, continuous coil of wire. When the magnet is quickly roated about a vertical axis until the opposite end of the madnet points into the coil, when looking past the magnet at the coils, the induced current in the loops of wire will be:
a. clockwise
b.counterclockwise
c.greater than if the magnet is just pulled away
d.both a & b
e. both a & c
2. The rectangle below represents a block of material through which positive charge carriers move. When the left end is connected to the + terminal of a battery and the right end is connected to the - terminal of this battery a current shall flow through the metal.
____________________
Bottom
If a magnetic field is applied so that it's perpendicular to the plane of this paper and directed down toward it, an induced emf will be stablished with + on the:
a.top face of the block and - on the bottom face
b.bottom face of the block and - on the top face
c.face of the block nearest you and - on the face opposite this
d.right end face of the block and - on the opposite, left end face
e.none of these
3. Electrons move with a drift velocity of 1e-5m/s through a copper wire when a 5 A current flows through it. This wire has a diameter of 3.2 mm/ When the wire is held so it's perpendicular to the Earth's's B of the 5e-5 T, what will be the magnitude of the induced Hall emf?
a. zero
b. 10^-12 V
c. 10^-10 V
d. 10^-7 V
E. none of these
a. clockwise
b.counterclockwise
d.both a & b
e. both a & c
Bottom
e.none of these
a. zero
b. 10^-12 V
c. 10^-10 V
d. 10^-7 V
E. none of these
