What Eyepiece Focal Length Achieves a 350x Magnification in a Microscope?
To achieve a 350x magnification in a microscope with a 21 cm distance between the objective and eyepiece lenses and a 5.5 mm focal length for the objective lens, the eyepiece focal length must be 2.4 cm. The discussion highlights two equations for calculating magnification, with the second equation incorporating a +25 adjustment for when the final image is formed at the near point (25 cm from the eye). The first equation does not include this adjustment and is used when the image is at infinity. The choice of formula depends on the image distance, which is not specified in the problem. Understanding these distinctions is crucial for accurate calculations in microscopy.
agenttiny200
The distance between the objective and eyepiece lenses in a microscope is 21cm . The objective lens has a focal length of 5.5mm. What eyepiece focal length will give the microscope an overall angular magnification of 350?
M=(25*d)/(fe*fo) or
M=(25*d)/(fe*fo)+25?
where d=5.5cm, M=350, f0=21cm, and fe is unknown
The online program says the answer is 2.4cm using the second equation, so I'm wondering why I don't use the first equation that doesn't add +25, and where the +25 came from? It's really bugging me. (I do not mean the first 25 which is being multiplied by d).
Is any more information given by the question? Is the eye relaxed or strained? A strained eye has a different equation from a relaxed eye.
Nope. Doesn't give any extra information. That's it.
There are two formula. The microscope can be setup so that the final image forms either at the near point
(25 cm from the eye) or very far away (infinity). The +25 formula is used when the image is formed at the near point (N = 25 cm) and the other one is used if it is formed very far away.
Likes RaulTheUCSCSlug
Explained here
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
