roineust said:
...snip......
A hobby telescope zooms in the order of 100X, Hubble zooms in the order of 10 times stronger, so it would zoom in the order of 1,000X, James Webb zooms in the order of 10 times stronger, so it would zoom in the order of 10,000X, James Webb, coupled by gravitational lensing, of type such as Abell 2744, zooms in the order of 10 times stronger, so they would zoom 100,000X ??
You are missing some important factors in your thoughts.
Magnification
isn't the be all and end all of a good telescope, be it your home one or one on a mountain or in orbit.
1) Lens or mirror diameter is the most important as it determines how much light is collected ... bigger is better ! therefore the collection of more light = the ability to see fainter and more distant objects
2) Resolution
3) and least important is magnification
Now talking of magnification ...
You cannot compare magnification of the Hubble or most other science observatory telescopes to your telescope because those telescopes don't use eyepieces, that is, they are for photographic imaging, instead of an eyepiece there is a camera. In fact, the magnification factor of these big telescopes like Keck, Hubble etc
is not even mentioned in most science articles.
We will consider that you haven't told us anything about this scope of yours that supposedly has a mag capability of 100x ... ( this statement is meaningless without more information about your scope.
Now magnification of a telescope is worked out very easily, it is the Focal Length of the objective lens divided by the focal length of the eyepiece. eg.
So, let's say your scope has a focal length of 300mm ( it will be written on the label on your scope) and you use a 40mm eyepiece ( will be written on the eyepiece)
therefore the magnification = 300 / 40 = 7.5x.
you might also have a 15mm eyepiece so again the magnification now is
300 / 15 = 20x
From that you can see that different eyepieces will provide different magnifications for a given telescope.
Also note, there is a HUGE difference between maximum magnification of your scope ( any scope) and the
maximum USEABLE magnification ( which will be significantly less). Maximum useable magnification is where
you can still get a sharp and clear view. Atmospheric conditions also have a huge bearing on this which is one big reason why Hubble was placed in orbit at that time.
That feature of Hubble is now pretty much overcome these days with ground based scopes that use
adaptive optics that can produce results comparable to those from the Hubble and the ground based scopes are now 3 to 10 times the diameter of the Hubble's 2.4 metre diameter mirror.
I have 3 scopes for night-time use ... pictures of them can be seen in other threads in this astro forum section.
A Celestron CPC925
Focal length of 2350mm, 2350 / 25mm eyepiece = 94 x magnification ( have various eyepieces)
I could stick a 6mm eyepiece into this scope and get 392 x magnification but I truly doubt that the seeing would be any good.
A Skywatcher EVO120
Focal length of 1000mm, 1000 / 25mm eyepiece = 40 x magnification
and my latest scope
A Skywatcher ESPRIT 100 ED
Focal length of 550mm, 550 / 25mm eyepiece = 22 x magnificationI really hope you are now starting to see that magnification is the least important of the features of a telescope. Light gathering ability and optical performance are so much more important.Here's a couple of good pages with all the info on working out telescope magnification etc ...
http://rocketmime.com/astronomy/Telescope/Magnification.html
https://cosmicpursuits.com/943/telescopes-explained/
https://user.xmission.com/~alanne/AstronomyFormulas.html
http://www.pgccphy.net/ref/hst-optics.pdfregards
Dave
