Magnitude and Direction of a charge interaction
The discussion focuses on determining the direction of the force on a -10 nC charge, specifically the angle measured clockwise from the +x-axis. The magnitude of the force is calculated to be 4.3E-3 N. The user initially calculated components of the forces from two other charges but expressed confusion regarding the angle measurement, particularly the clockwise versus counterclockwise distinction. A suggestion was made to clarify the coordinate axes and double-check calculations, emphasizing that the force from the -5 nC charge only has a y-component, while the force from the 15 nC charge has both x and y components. The conversation highlights the importance of accurately interpreting vector directions in electrostatic problems.
themonk
What is the direction of the force \vec{F} on the -10 nC charge in the figure? Give your answer as an angle measured cw from the +x-axis. Problem 26.39 in Physics for Scientists and Engineers Second Edition by Knight
Magnitude of the force is 4.3E-3 N
As far as I know, this is the only relevant equations:
\vec{F}=k*q_{1}*q_{2}/d^{2}
I already found the magnitude as listed above. But I need to find \theta in the clockwise direction.
The force of A (being the -5 nC charge) I figured was direction -4.3E-4 \hat{j} and -1.28E-3 \hat{i} and the other charge had a force of -4.5E-3 I double checked with an answer from someone else (MasteringPhysics also said it was correct). I figured I would use a trigonometric function for the final part, ie the angle measured in the clockwise direction. In lab we used tangent, but was confused as to why (tangent is opposite over adjacent):
tan(\theta)=4.07E-3/1.28E-3 ==> \theta=tan^{-1}(3.179)
which is 72.54 degrees. I added 180 to it to get 252.54, but apparently that is not correct (I don't completely understand the cw and ccw part).
Is there any line of thought that I should proceed with?
(sorry about my English)
Show the coordinate axes and the forces in your figure, please.
ehild
I can't edit the problem, but the x-axis (\hat{i}) is left-right and the y-axis (\hat{j}) would be up-down, if I am not mistaken. The origin would then be at the -10nC.
In this case the force on the -10 nC charge from the -5 nC one has only y component, and that form the 15 nC charge has both x and y components. Check your calculation and text.
ehild
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
