Les talons
- 28
"A rod 55cm long and 1.0cm in radius carries a 4.4μC charge distributed uniformly over its length. What is the approximate magnitude of the electric field 4.0mm from the rod surface, not near either end? What is the approximate magnitude of the electric field 32m from the rod?"
E = q_enclosed/(2∏*ε_0*r*L)
For the field at 4.0mm, I calculated the magnitude as: (4.4/1*10^6)N/(2∏*8.85*10^(-12)*0.014*0.55)C = 1.0*10^7 N/C
For the field at 32m, I calculated it the same way: (4.4/1*10^6)N/(2∏*8.85*10^(-12)*32.01*0.55)C = 4.5*10^3 N/C
The answer for the field I got at 4.0mm is correct, but the magnitude found at 32m is wrong. I don't see how the formula for the magnitude would change in the two situations. The change in magnitude looks good to me since the distance from the rod increases by a factor of 10^3. There is still not any flux through the ends of the rod, so that would not change the calculation, either. I must be missing something really obvious. Thanks for reading!
