Calculating the Magnitude of a Projected Force
The discussion focuses on calculating the magnitude of the projection of a force vector F along a unit vector u. Participants clarify that the projection can be found using the dot product of F and u, emphasizing the importance of correctly identifying the components of u based on the given angle. There is confusion regarding the signs and values of the components of F, which leads to corrections in calculations. Ultimately, the correct components of u are established, allowing for the successful calculation of the projection, resulting in a final answer of 290 N to two significant figures. The conversation highlights the importance of understanding unit vectors and the dot product in vector projection problems.
Robb
Determine the magnitude of the projection of force F = 700 N along the u axis
A(-2, 4, 4)
r(AO) = 2i -4j - 4k
r(AO mag)= 6
u(AO) = 1/3i - 2/3j - 2/3k
F(AO) = 233.3333i - 466.6667j - 466.6667k
I'm not sure where to go from here. The only info I can figure about u is the 30 degree angle between it and the y axis.
This is a vector problem. Do you know how to find the projection of one vector along the direction of another?
F dotted with u(AO)
Robb said:
F dotted with u(AO)
Hmm. Don't you mean F dotted with u? Note that F lies along the direction OA. So you'll need to construct a vector for F and another for the u unit vector. That 30° angle should come in handy for the latter.
F = 233.3333i - 466.6667j - 466.6667k
I guess I'm just not seeing the u unit vector. And, yes, that is what i meant.
I think you need to check the signs of your F components. It looks to me from the diagram that F is pointing towards the negative x-axis, positive y-axis, and positive z-axis.
The u unit vector should lie along the u-axis. Use a bit of trig to find the x and y components. It appears to lie in the x-y plane...
u(x) = 4/cos30 = 4.62
u(y) = sqrt(4.62^2 - 4^2) = 2.31
u = .5i +.866j
F(u) = (-233.3333i)(.5) + (466.6667)(.866) = 287.5
They want the answer to two significant figures
The simplest approach to finding a unit vector is to imagine that it sits within a unit circle, and then the sine and cosine of a suitable angle will give your the components directly. The magnitude of any vector with unit length is always unity, just like the radius of the unit circle.
The axis u is indicated as having an angle of 30° with respect to the y-axis. So you should expect the y-component to be the cosine of the angle and the x-component to be the sine of the angle. You seem to have found the opposite (and I don't really understand where your value of 4 came from... there's nothing indicated in the figure that ascribes a dimension of 4 in relation to the u-axis).
This is what you have to work with:
Yep, I understand that. I was grabbing at straws because I'm not sure how to get values for u.
Okay, so are you good to go now?
So, I have u(y) = ucos30 and u(x) = usin30
I guess where I'm lost in all of this is what is u? I need to use the dot product to solve but without a value for the above components how can I do that. Feeling a little blind here.
u is a unit vector along the positive u-axis. Refer to the diagram that I posted.
All you need in order to find a projection along a given direction is to dot a given vector with a unit vector in the desired direction. Works with any unit vector; You can try it with your F vector and the unit vectors for the x,y, and z axis if you like. Take the dot product of F with any of the axes unit vectors and you should "extract" that component from the F vector.
usin30 + ucos30 = 1
u = .7214
u(x) = .3607
u(y) = .6248
F dot u = 209
To two sig figs F(u) = 210
Robb said:
usin30 + ucos30 = 1
No, how do vector components add?
u = .7214
u(x) = .3607
u(y) = .6248
u can't be both a scalar and a vector. Besides, the sine and cosines all by themselves satisfy the requirement of unit vector components. ##sin^2 + cos^2 = 1##. So just use the sine and cosine as the components of u.
F dot u = 209
You'll need to re-do that with the fixed u.
yeah, that wasn't real smart.
F dot u = (-233.3333)(.5) + (466.6667)(.8661) = 287.5
two sig figs = 290
two sig figs = 290
You've mixed up the components of u again. Look at the diagram in post #8. Is the sine of the angle along the y-axis or the x-axis?
sin=x
cos=y
Robb said:
sin=x
cos=y
Right. And sin(30°) = 1/2, while cos(30°) = √3 / 2.
I agree: (-233.333)(.5) + (466.6667)(.8661) = 287.5 or 290
D'oh! I apologize. I misread and jumped without engaging my brain o0)
You have indeed got u sorted out now. So your result is correct :approve:
No problem. My brain has not been engaged this entire problem. I kept thinking I needed to find a value for u when u is simply 1 because it is a unit vector! Thanks for your help, I learned a couple things on this one!
