What Constant Makes a Function Holomorphic?
  • Thread starter Thread starter jimmycricket
    Function
jimmycricket
Find a constant k such that the function v(x,y) = y^3-4xy +kx^2y can be the imaginary part of a holomorphic function f on C
The Cauchy-Riemann equations: u_x=v_y and u_y=-v_x
So far I have taken the partial derivatives of v w.r.t y and equated it to u_x and then integrated w.r.t x giving:
u=3xy^2-2x^2y+(k/3)x^3+f(y)
Then differentiating w.r.t y to give:
u_y=6xy-2x^2y+(k/3)x^3y+f'(y)
Next I equate this to -v_x giving:
6xy-2x^2y+(k/3)x^3y+f'(y)=4y-2kxy
Now I am not sure which direction to head next or even if this is the correct approach to begin with. Help is greatly appreciated
You are working too hard. Can you show that Cauchy-Riemann implies ##v_{xx}+v_{yy}=0##? You don't really need to find u.
u=3xy^2-\color{red}{2x^2y}+(k/3)x^3+f(y)
Your method is OK and will solve the problem. But you have mistakes in your work. Hard to point out your errors since you omitted some steps. In particular, the term in red is incorrect.
Dick and LCKurtz thanks both for replying. Dick: following your method I get v_{xx}+v_{yy}=2ky+6y=0 \rightarrow k=-3
This method is showing that the function is harmonic for k=-3. Is this sufficient for answering the question of which k makes the function holomorphic?
Yes, if the function is holomorphic then v needs to be harmonic. So the only possible value is k=(-3).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
