How can I use a MOSFET and voltage multiplier to generate a high voltage spark?
  • Thread starter Thread starter Curl
    Mosfet Spark
To generate a high voltage spark across a 0.05mm gap, a spark plug ignition circuit from a lawn mower can be adapted for use. A voltage multiplier circuit, consisting of multiple diodes and capacitors, can effectively increase voltage output, and a MOSFET can be used to control this circuit with a micro-controller. Insulated wiring is essential due to the high voltage involved, and safety precautions must be prioritized. Modifications will be necessary for integrating the micro-controller into the ignition circuit. Consulting with an experienced engineer is advisable to ensure the circuit is safe and effective.
Curl
I need to make a large voltage, possibly to make a spark across a 0.05mm gap or at least to make a very large voltage across a resistor. I need this to be triggered digitally by a micro-controller.
I was thinking of setting up an inductor and a power MOSFET, but I don't know if this will work. Can anyone help sketch a circuit that would accomplish what I described?
Thanks!
Thanks!
From our PMs, it sounds like you just need a spark plug circuit. Can you just use a spark plug ignition circuit off of a lawn mower or similar?
My thoughts exactly, a simple ignition circuit is all you will need. In regards to triggering it by a micro-controller will definitely require a bit of modification.
Not too sure what you're exactly trying to do so it's hard to say.
http://img502.imageshack.us/img502/5589/10322599.jpg
There's an example.
Needless to say, if you're going to be trying to get sparks, that's kV running from the coil to the plug, so use insulated wiring, preferably BOSCH or something similar from auto shops.
As to triggering it from a micro-controller, how about triggering the battery with a simple switch breaking contact with the rest of the circuit when you don't want it turned on?*Image taken from Fundamentals of Electric Circuits (4th Ed) - Alexander, Sadiku p.353
I would suggest using a voltage multiplier circuit to achieve your goal of creating a large voltage. This circuit consists of multiple stages of diodes and capacitors that can increase the voltage output. You can control the triggering of the voltage multiplier using a MOSFET, which can be controlled by the micro-controller. This setup will allow you to generate a high voltage pulse that can create a spark across a small gap or produce a large voltage across a resistor. I would recommend consulting with a professional or experienced engineer to help you sketch out a specific circuit that fits your needs and ensure safety precautions are taken.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
