Making an explosive volcano without chemicals? HELP
  • Thread starter Thread starter DChalo
    Chemicals Volcano
The original poster seeks to create a volcano model that simulates an eruption without using chemical reactions, instead relying on mechanical components to achieve the desired effect. The project aims to be visually impressive while adhering to specific constraints regarding materials.
  • Some participants question the feasibility of creating a non-chemical eruption model and suggest considering the principles of real-life volcanoes, such as mechanical pressure. Others inquire about devices that can mechanically expel fluids, prompting a discussion on potential methods to achieve the desired effect.
The discussion is ongoing, with participants exploring various interpretations of the project requirements. Some guidance has been provided regarding the principles of mechanical action and fluid dynamics, but there is no explicit consensus on a specific approach.
There is an emphasis on the importance of creativity and personal effort in the project, with one participant highlighting that the original poster should engage in their own research and development rather than relying solely on external guidance.
DChalo
Making an explosive volcano without chemicals? HELP!
So here's the deal. I have to make a volcano that does not use chemicals or substances (potassium nitrate, baking soda, vinegar). It has to use mechanical parts to symbolize a volcanic eruption (ie springs for pressure). Any ideas? I have literally no thoughts on how to make it. I also want it to be impressive. Thanks for any help
Welcome to PF;
It is not possible to make anything out of any material without chemicals - everything is a chemical.
But I see what you mean - you want to get a model eruption without relying on a chemical reaction.
You realize that real-life volcanos fit the project description - what principles do they use? (i.e. mechanical or pressure?) How do they exploit the principles? Can you think of something that does something similar on a smaller scale?
Basically what you want is to get some model "magma" or something to come out the top of a papier mache cone yes? What sort of devices are there where some mechanical action causes a fluid to come out a hole?
Any ideas?
I'm not going to do you R&D for you.
I've already pointed you in two good directions - the idea of these projects is that you get used to applying your own imagination. If I tell you what to do you won't learn.
Seriously: if you don't know how to squirt fluids about, you have more serious problems than I can deal with.
