Calculating Velocity from Conservation of Momentum: A Science Tutorial
  • Thread starter Thread starter AndrewMorris
The discussion focuses on using conservation of momentum to calculate velocity, with a specific example yielding a velocity of 2.86 m/s. The original calculation appears correct, but a participant suggests double-checking the number 400 for potential errors. They recommend using symbolic calculations and maintaining consistent units to avoid mistakes. Acknowledgment of common errors in math is shared, emphasizing that such mistakes can happen to anyone. The conversation highlights the importance of careful calculation and verification in physics problems.
AndrewMorris
My daughter was asked this question:
A person of mass 60 kg running at 8 m/s reaches a wagon of mass 80 kg going at 2 m/s and jumps onto it. Calculate the velocity of the wagon immediately after the person jumps on.
total momentum before impact = total momentum after impact
Using conservation of momentum I would say (60 x 8) + (80 x 2) = (60 + 80) v
so v = 400/140 = 2.86 m/s.
However, this is not one of the multiple choice responses. What am I doing wrong?
Setup looks right. But check the number 400.
Apart from that, consider using symbolic calculations and only insert your numbers at the end. It often avoids this kind of mistakes. Or at least use units throughout.
oh man, I used to be good at maths, honest. Thanks :-)
It was just a careless error. Happens to us all :oldsmile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
