Balancing Forces on a Scale: Man with Pulleys and Tensions
  • Thread starter Thread starter wah31
    Scale
The discussion revolves around a physics problem involving a man on a scale pulling a rope connected to pulleys. The initial calculations presented included a tension of T1=250 N and a scale reading of P=125 kg, which were questioned by other participants. It was concluded that the scale should actually indicate 75 kg, as the man's weight minus the pull from T1 results in a net force of 750 N. The group agreed that while the tensions were correct, the scale reading was miscalculated. The forum emphasizes the importance of validating calculations and understanding force dynamics in physics problems.
wah31
Man standing on scale and pulling on a rope connected to two pulleys
The mass of the man is: m=100 kg
The weight of the pulleys, cables, balance, and the frictions are not taken into account
g=10m x s-2
3. The Attempt at a Solution
the force that the man should draw in order to maitain balance:
T1=250 N
The weight displayed on the scale:
P= 125 kg
Other tensions:
T2=250 N
T3=500 N
T4=500 N
T5=1000 N
Do your agree with that ?
Thank you..
You have not laid out the question properly ... what information is given in the question?
You just have to validate or not thes values (T1, P, T2, T3, T4, T5)
g=10m x s-2
T1=250 N
P= 125 kg
Other tensions:
T2=250 N
T3=500 N
T4=500 N
T5=1000 N
Thank you..
I agree with all the tensions, but I do not understand how you got 125kg for the scale reading. Consider again which way the forces act on the man.
I'm not convinced either
I thought about it..
Yes I agree there is something wrong
What do we know for sure ? ...T1= T2 and T3 =T4 ... 4xT1 = 2xT4 = T5 and T5 is supporting all the mass = 100kg = 1000N ... so all the tensions are correct .
The weight indicated on the scale must be the man's weight , minus the the pull from T1 ... 1000 - 250 = 750N scale should indicate 75Kg not 125kg
Yes you are right :check:
Thank you.. it's cool :oldbiggrin:
This is a homework forum. We point out errors, provide hints, explain principles... We do not post solutions.
