Calculating Frequency of Oscillating Mass on a Spring
The position of a mass oscillating on a spring is described by the equation x(t) = (18.3 cm)cos[(2.35 s^-1)t]. To find the frequency of this motion, the relationship f = ω/(2π) can be applied, where ω is the angular frequency. In this case, ω is given as 2.35 s^-1, leading to the calculation of frequency as f = 2.35 s^-1 / (2π). There is some confusion regarding the relationship between frequency and period, but it is clarified that frequency is the reciprocal of the period. The discussion emphasizes the correct application of the formulas to determine the frequency accurately.
aleferesco
The position of a mass oscillating on a spring is given by x(t) = (18.3cm)cos[(2.35s^-1)t] .
What is the frequency of this motion?
X= Amplitude x Cos (2pi/T x time)
I know that frequency= 1/Period, I am trying to use f= 1/(2.35s^-1) but it doesn't seem correct. Also I've tried multiplying the amplitude by 2... f= 1/(18.3cm)x2
Thanks
so the form is x(t) = Acos( \omega t )
where \omega = 2 \pi f
Can you see how this helps you?
so omega= 2.35s^-1
and so to find frequency I could just do f=2.35s^-1/2pi
I'm not sure about the reversing 1/1/T = s^-1
Sorry I don't understand what you're saying here, but yes:
f = \frac{\omega}{2\pi}
are you confused because omega is a reciprocal? That should play no part in exchanging frequency with period. So just follow that formula and you should be fine.
Note: I have not solved the problem numerically, but I can tell it's going to be a very small answer.
Thank you very much!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
