Mass Moment of inertia of a cylinder with 4 holes?
To calculate the mass moment of inertia of a cylinder with four holes, first convert the weight density of 490 lb/ft³ to mass density by dividing by 32.2. Next, determine the mass of the solid cylinder without holes and the mass of each hole. Use the parallel axis theorem to calculate the moment of inertia for each hole about the center axis, then compute the moment of inertia for the entire solid cylinder. Finally, subtract the moment of inertia of the holes from that of the solid cylinder to find the total moment of inertia. This approach is confirmed as correct for solving the problem.
qpham26
Hi I was reviewing for my final and I came across this problem:
Problem:
Basically there is a 6in long cylinder with dia = 24in
Given weight density: 490 lb/ft^3
Each Hole is drilled symmetrically, each has 6in dia and equally space around a 10in dia circle concentric with the cylinder.
This is the picture of the frontview of the cylinder: https://lh4.googleusercontent.com/-8m1r4npC7cg/T11OqGF6qhI/AAAAAAAAABY/4v2HCrEqhd4/s333/cyinder.png Thanks for your time and consideration.
Appreciate it!
Approach
So what I would do is:
-First get that weight density into mass density by dividing it by 32.2
-Then find the mass of the cylinder without holes.
-Find mass of each holes.
-calculate the M of I of each hole about the center axis (parallel axis theorem)
-calculate the M of I of the whole solid cylinder (no holes)
-subtract the M of I of the holes from the whole cylinder
Will I get the correct answer based on the technique above?
That is a correct approach.
ehild
Thanks and for the mass of the cylinder, the unit is slug right?
Thanks again.
I am sorry, I am not familiar with imperial units. But Wikipedia says it is slug.
The slug is a unit of mass associated with Imperial units. It is a mass that accelerates by 1 ft/s2 when a force of one pound-force (lbF) is exerted on it.
http://en.wikipedia.org/wiki/Slug_(mass )
ehild
Problem:
Appreciate it!
Approach
yah...
this only is the right way of solving it.
