Mass of a black hole - given only the diameter
The discussion revolves around calculating the mass of a mini black hole using its diameter, specifically that of a proton. The initial calculations were incorrect due to a misunderstanding of the Schwarzschild radius formula and the inclusion of a square root. After clarifying the correct formula, participants determined that the mass should be calculated as m = rc^2 / (2G), leading to a mass of approximately 3.37 x 10^11 kg. The conversation highlights the importance of accurately applying gravitational equations in astrophysics.
PirateFan308
Cosmologists have speculated that black holes the size of a proton could have formed during the early days of the Big Bang when the universe began. If we take the diameter of a proton to be 1.0*10^{-15}, what would be the mass of a mini black hole?
v=\sqrt{\frac{Gm}{r}}
m=\frac{v^{2}r}{G}
m=\frac{(3.0*10^{8})^{2}(0.5*10^{-15})}{(6.67*10^{-11})}
m=6.75*10^{11} kg
It says that this is wrong, but I can't find my mistake. Thanks!
The Schwarzschild radius is given by:
r_s = \frac{2 G M}{c^2}
I think you forgot the factor of 2.
EDIT: D'Oh. No square root! Fixed it.
r_s = \sqrt{\frac{2 G M}{c^2}}
Isn't the schwarzchild radius simply:
R_s=\frac{2GM}{c^2}
So this would rearrange to
m=\frac{rc^2}{2G}
and plugging in the values, I would get m=3.37*10^{11}kg
Is this now correct?
R_s=\frac{2GM}{c^2}
m=\frac{rc^2}{2G}
Yes, and yes. Sorry about the square root distraction, I don't know where my head was at!
Thanks for the help!
