Mass of an object up inclined plain
  • Thread starter Thread starter Paulbird20
    Inclined Mass
To determine Brisket's mass while moving down a frictionless inclined plane at a 24° angle, the applied force of 1008N must be balanced against the gravitational component acting down the ramp. The correct approach involves using the equation mg*sin(24°) - FR = ma, where 'm' is the mass, 'g' is the acceleration due to gravity, and 'a' is the acceleration of 0.29m/s². A free body diagram is essential for visualizing the forces acting on Brisket. The initial calculation of mass using Fn = mg cos(24°) is incorrect due to not accounting for the direction of acceleration. Properly applying the forces will yield the correct mass of Brisket.
Paulbird20
applied all the force FR=1008N that I could to the (massless, unstretchable) rope in an effort to pull Brisket into the trailer, up the ramp that formed an angle of 24.0° with the ground. Brisket moved down the ramp with an acceleration of magnitude 0.29m/s2. With this information, and assuming the ramp is frictionless, what is Brisket's mass (in kg)?
What i have done so far is Fn = mg cos (angle) and that is 1008/ 9.8cos 24(degrees)= 112.59 kg but it is not correct can anyone direct me into the right direction
Much appreciated
You're trying to pull the object UP the ramp, but it's moving DOWN. Draw a free body diagram!
The equation should be
mg*sin(24)(downward force) - FR = ma
