Massless pulley and acceleration
The discussion revolves around a scenario involving a massless pulley system with two blocks, where one block (m2) is heavier than the other (m1). The original poster questions how the lack of mass in the moveable pulley affects the acceleration of the blocks, particularly since they expect both blocks to have the same acceleration due to the ideal string assumption.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of a massless pulley on the system's acceleration and forces. Questions arise about how a massless object can have acceleration if the net force acting on it is zero. Some participants discuss the relationship between the tension in the string and the acceleration of the blocks.
The discussion is ongoing, with various interpretations being explored regarding the effects of massless objects on acceleration and tension. Some participants provide insights into free body diagrams and the relationships between the forces acting on the blocks and the pulley, while others express confusion about the setup and seek clarification.
There is uncertainty regarding the attachment of the pulley to the blocks, as well as the implications of changing the mass of one of the blocks. The original question also involves finding the tensions in the string, which adds complexity to the discussion.
iloveannaw
In the following situation (see attachment) both pulleys and the string have zero mass. If [tex]m_{2} > m_{1}[/tex] we would expect a net force and therefore an acceleration in the direction of the net force. But if pulley 2, which is moveable, has no mass the sum of the forces acting on it is zero. How does this affect the acceleration of the blocks (which I would expect to have same acceleration - ideal string etc.)?
Newton's II
a moveable pulley 2 only means that it move along the string, without a change in its x coordinate. i.e. meaning it will only move up or down depending whether m1 > or < m2.
what is your workings?
hi thanks, i realize it will only move vertically - my question is since both blocks should have the same acceleration, pulley 2 will also have that acceleration (whatever it may be) but since no net force can act on that pulley how can it have an acceleration?
does this mean that the acceleration is zero?
thanks
correct me if I am wrong but massless objects are an ill-defined concept to begin with. Considering F = ma
a= F/0 or infinity in other words.
I wouldn't say it's 0 acceleration.
wouldn't that mean the tension in the string was also infinite? btw the actual question was to find tensions T_1 and T_2.
No. Tension is a force, do not confuse it with resultant force!
In a way, it is true that the acceleration of the string is infinity as well.
You should be considering either of the mass blocks as a FBD
are you sure? if we look at m_1: it must have the same acceleration as m_2 and pulley_2.
If acceleration of pulley_2 was infinite then the acceleration of m_1 would also be inf. and so would the force acting on it (in other words the tension), since m_1 != 0. Since we are dealing with a massless string the tension is constant throughout. This means the tension at any part of the string would be infinite.
The more mass an object has, the slower the acceleration when subjected to the same force.
No doubt the pulley will experience infinite acceleration, but do not simply equate this to be the same as m1's acceleration.
There are many other factors to consider such as how the pulley is attached to the block? If it is rigidly attached, then there would be a retarding force by m2 on the pulley, during the fall, if the acceleration of the pulley is faster than that of the block, but then again, the faster acceleration of the pulley does not affect m2's acceleration either because it's massless to start with rememeber?
Don't confuse yourself, work it out like i said. consider a fbd on m1 and m2.
sorry had to go to a lecture,
yeah, i should have said that the very first thing i did was to draw free body diagrams and try to work out the sum of the forces in the relevant directions for the bodies involved.
thanks for your help so far but I would prefer a straight answer to my original question. I don't know how the pulley is attached to the block, I imagine it is a chain or another piece of string.
I don't think there's any big deal about how the objects are connected, it's a simple problem. I do have a problem with your diagram, however; to me it seems that [tex]m_1[/tex] is attached directly to the massless string, whereas [tex]m_2[/tex] is not even connected to the string, only to the pulley(in turn - connected to the string).
Isn't the question simply asking what would happen if [tex]m_2[/tex] were to suddenly become massless?
If so;
1. What happens to each block if [tex]m_2 > m_1[/tex] (as stated)?
2. What happens when [tex]m_2 < m_1[/tex]
The accelerations of the blocks are not the same.
The net force F on the massless pulley (m=0) must be zero at arbitrary acceleration as F=ma=0.
ehild
  • · Replies 18 ·
  • · Replies 17 ·
