Master and Slave Cylinder at different heights
  • Thread starter Thread starter nmsurobert
    Cylinder Master
The discussion revolves around the relationship between the heights of master and slave cylinders in a hydraulic system and how it affects the force produced at the slave cylinder. It is established that an increase in the height of the master cylinder results in an increase in the force at the slave cylinder due to gravitational head. Concerns are raised about the applicability of the pressure equation P = ρgh in this context, leading to clarifications that pressure, rather than force, is what gets added. The final consensus is that the force at the slave cylinder can be expressed as Fs = (As)Fm/Am + ρghm, emphasizing that the weight of the fluid above the slave cylinder contributes to a constant nonzero force. This understanding highlights the importance of correctly applying pressure and force relationships in hydraulic systems.
nmsurobert
Suppose the master cylinder in a hydraulic system is at a greater height than the slave cylinder. Explain how this will affect the force produced at the slave cylinder.
P = F/A
F[SUB]1[/SUB]/A[SUB]1[/SUB] = F[SUB]2[/SUB]/A[SUB]2[/SUB]
P = ρgh
I think I've made sense of this.
m: master, s:slave
Fm/Am = Fs/As
Fs = As(Fm/Am)
Fs = (As)ρghm
So with that said, if the height of the master cylinder increases then the F produced by the slave will also increase. Anyone see any problems here?
My concern is that P = ρgh isn't applicable here. Thanks.
nmsurobert said:
Problem Statement: Suppose the master cylinder in a hydraulic system is at a greater height than the slave cylinder. Explain how this will affect the force produced at the slave cylinder.
Relevant Equations: P = F/A
F1/A1 = F2/A2
P = ρgh
m: master, s:slave
Fm/Am = Fs/As
Fs = As(Fm/Am)
Fs = (As)ρghm
Your concern is correct and the equations need to reflect this. If Fm is zero there is nonzero Fs from the gravitational head. If Fm is nonzero then it adds to it.
I think I understand what you’re saying. Can I compensate for that by just doing this?
Fs = (As)ρghm + Fm
Or something like this. Or add mg?
Fs = (As)ρghm + Fm
Close but Its the pressure that gets added to.
In particular in the limit of ρ=zero you should recover the previous result.
This way the force applied to the master cylinder can be zero but the force applied to the slave cannot be zero because of the pressure created by the difference in height.
Your idea is correct but ρghm is a pressure. You now have it equated to a force.
Ahh that makes sense. The only thing that makes sense to me is to use weight. If the fluid is on top of the slave cylinder then it’s weight applies a constant force to the slave cylinder always keeping that force nonzero.
  • · Replies 17 ·
  • · Replies 21 ·
