Master Loop and Nodal Analysis with Expert Tips and E-books
For mastering loop and nodal analysis, several e-books and resources are recommended, including academic materials from schools and Google Scholar for specific problems. PowerPoint presentations and online articles can provide additional insights into the methods. Visiting a library to find books on circuit analysis is also suggested, as these texts are foundational in electrical engineering. Engaging with knowledgeable peers or forums can further enhance understanding and implementation of these techniques. Utilizing these resources can significantly improve problem-solving skills in loop and nodal analysis.
AK2
Could u guys reccomend some e books for loop and nodal analysis . I am having some problems implenting the methods to solve poblems. or may be u could give me some tips
I can help u if u want
Some e-books that are creditable are mostly from your school or I would search the Google scholar website for the particular problem.
Another tip is to go the library and borrow books that say circuit analysis or circuit principle ,etc,.. They are everywhere since they are fundamental of electrical engineering technology.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
