Material that can be bent repetitively without fatique?
  • Thread starter Thread starter nomisme
    Material
The discussion revolves around identifying materials that can be bent repetitively without experiencing fatigue or permanent deformation. Participants explore various material types, including elastic and non-elastic options, and consider both composites and specific examples of usage.
  • One participant inquires about materials that can be frequently bent into different shapes without breaking or losing strength, mentioning sheet spring and questioning its performance at 70 to 80 degrees of bending.
  • Another participant suggests that an amorphous polymer in its rubbery plateau region, such as cross-poly(butadiene-stat-styrene), might be suitable, and discusses the potential of a particle reinforced polymer matrix, noting possible adhesion issues.
  • A participant references nickel-titanium as a material of interest, linking to a Wikipedia page for further information.
  • Another participant humorously mentions silly putty as a potential option.
  • One participant recalls that lead metal may self-anneal at room temperature, suggesting it could be bent repeatedly without exhibiting fatigue.
Participants present a variety of materials and ideas, but there is no consensus on a single best option or approach. Multiple competing views and suggestions remain throughout the discussion.
Some suggestions depend on specific conditions such as temperature and the nature of the bending process, which may not be fully explored or defined in the discussion.
Individuals interested in material science, engineering applications, or those seeking solutions for flexible design challenges may find this discussion relevant.
nomisme
I am looking for a material that I can bend easily into different desired shape frequently without breaking or losing strength. The material can either be elastic or not elastic. I know sheet spring can do but if I bend it like 70 to 80 degrees will it permanently deformed or become fatique?
Will you recommend a few material composite that allow me to do that? or any examples of this usage?
thanks
Some thoughts:
If it doesn't need to stay by itself in the shape that it's forced into, perhaps a amorphous polymer that is in it's rubbery plateau region in the operating temperature would be suitable. For an example (at the room temperature) cross-poly(butadiene-stat-styrene) that is used in rubber bands. If it needs to be a composite material, maybe a particle reinforced polymer matrix where the matrix material is in that same rubbery plateau state. Though there might be problems with adhesion between the particles and the matrix if the composite is being bent a lot.
The first thing that came into my mind when reading your post was the silicone cupcake moulds that can be turned inside out. Now I think I need to visit a bakery...
Silly putty
Socks
I seem to recall that lead metal (Pb) self-anneals at room temperature. So given time it heals after being bent, then can be bent again, and this way never exhibits fatigue.
17K
  • · Replies 21 ·
11K
