Math Challenge - August 2020
104 replies · 21K views · last reply
fresh_42 said:
11. Let ##a < b < c < d## be real numbers. Sort ##x = ab + cd, y = bc + ad, z = ac + bd## and prove it.
The sorted order is ##y < z < x##, which is proved as follows by first proving 2 pairwise inequalities.
y - z = (bc + ad) - (ac + bd) = c(b-a) + d(a-b) = (c-d)(b-a) < 0
\Rightarrow (y - z) < 0 \Rightarrow y < z
where ##(c-d)(b-a) < 0## follows from the fact that ##c < d## and ##b > a## as per the given conditions.
x - z = (ab + cd) - (ac + bd) = a(b-c) + d(c-b) = (d-a)(c-b) > 0
\Rightarrow (x - z) > 0 \Rightarrow x > z
where ##(d-a)(c-b) > 0## follows from the fact that ##d > a## and ##c > b## as per the given conditions.
Combining the 2 inequalities gives the ordering inequality ##x > z > y##.
Problem 8.
I first state the Bohr-Mollerup theorem,
Let ##f:(0, \infty ) \rightarrow \mathbb R^+## be a function satisfying:
(i) ##f(x+1)=xf(x)##.
(ii) f is a log-convex function.
(iii) ##f(1)=1##.
##f(x)=\Gamma (x)## on it's domain.
##\Gamma## is meromorphic. The identity theorem states: If two meromorphic functions in ##\mathbb C## agree on a set with a limit point in ##\mathbb C##, then they agree everywhere in ##\mathbb C##. In particular, two meromorphic functions that agree on ##(0, \infty )## agree everywhere on ##\mathbb C##.
Thus condition (i) above holds in the complex plane. The two meromorphic functions, ##\Gamma (z+1)## and ##z\Gamma (z)##, that agree on ##(0, \infty )## implies ##\Gamma (z+1)=z\Gamma (z)## for all ##z \in \mathbb C##.
Wielant's theorem (https://www.jstor.org/stable/2975370) states that condition (ii) "f is a log-convex function" can be replaced by "##f(x)## is in the bounded strip ##\{ z\in \mathbb C | 1 \leq \mathfrak{ R}(z) \leq 2\}##".
Because ##F(z)## is in the bounded strip ##\{ z\in \mathbb C | 1 \leq \mathfrak{ R}(z) \leq 2\}## it satisfies the Bohr-Mollerup theorem, extended to the complex plane, up to a real constant ##F(1) = a## and thus ##F(z)=F(1)\Gamma (z)##.
Fred Wright said:
Problem 8.
(iii) ##f(1)=1##.
Well, problem #8 IS Wielandt's theorem. You just shifted the problem to Bohr-Mollerup. This is a bit like proving AC by Zorn.
There is still another - in a way elementary - proof possible. It uses a common theorem of complex analysis.
  • Haha
nuuskur said:
Of course *smacks forehead*. I had a thought maybe [itex]|z|\leq |e^z|[/itex], but that's not true in [itex]\mathbb C[/itex].
Nor is it true in ##\mathbb{R}## (negative numbers)!
SPOILER #9:g would have to restrict a continuous injection from the unit circle to the line {it: all t in R}, which is impossible. I.e. g is injective since e^g is injective, and the only complex numbers z with e^z lying on the unit circle are of form z = iy with y real, so g would hve to rstrict to a continuous injection from the unit circle to the "imaginary real line" of complex numbers of form iy with y real. Now it is immediate that a continuous map from the unit circle to a copy of the real line cannot be injective, since it has a maximum say M at p and a minimum say m at q, and then both arcs joining p to q on the circle must map onto the same interval [m,M], by the intermediate value theorem, so g is not injective.
With a larger weapon, one could say that since g is locally inverse to exp, it must be smooth if it is continuous, so using the strong smooth jordan curve theorem, it maps the unit circle isomorphically onto a smooth manifold, whose interior in the complex plane serves as its boundary. Then integrating the pullback of the closed form dtheta, gives a contradiction of the sort suggested earlier using Cauchy's theorem to integrate dz/z. I.e. since the pullback is closed, the integral of d of it over the interior of the manifold is zero, but since the boundary is parametrized by g, which pulls back the form dtheta to itself, the integral is 2π, contradicting stokes theorem.
More abstractly, these maps, if they existed, would induce a group homomorphism of fundamental groups, or of 1st homology groups, whose composition would be the identity map Z-->Z, while nonetheless factoring though the zero group Z-->0-->Z, an impossibility. Or as Bott put it long ago, to prove there is no such map, all you need is "a homotopy invariant functor that does not vanish on the circle".
By covering space theory, which is essentially the same argument, since exp is a covering space of C*, via C-->C*, a map C*-->C* can only factor through exp if it induces a map on fundamental groups, whose image is zero, not the case for the identity map. The existence of g would also violate unique path lifting, since the parametrization t-->e^2πit of the circle is via a lift t-->2πit, through the exponential covering that sends the two ends points 0 and 2π to different points of C, while the existence of g would give a lift that sends them both to the same point. This is the essential content of the earlier answer that any lift via g must be discontinuous as a map on the circle.
Oh yes, and now I see that my hint amounted to noticing that such a map g exists, only if one also exists for the restricted diagram: S^1-->iR-->S^1.
here is another similar argument. If such a g existed, its restriction to the unit circle would factor the injection from the unit circle to C*, through C, and hence would prove that this injection is homotopic to a constant. Then Cauchy's theorem, the homotopy version, would imply that any holomorphic differential in C* would integrate to zero over the unit circle, but that violates the integral of dz/z being 2πi, as pointed out earlier.
By the way this last argument, as well as those using fundamental group and 1st homology group, prove that even if you are allowed to replace exp by any continuous map of your choice, there still is no such map g. The fact that the given map is indeed exp, allows the more elementary first argument above, which only uses the intermediate value theorem.
PeroK said:
We have a function ##\beta (\theta)## for ##0 \le \theta < 2\pi## with ##\cos \beta (\theta) = \cos \theta## and ##\sin \beta (\theta) = \sin \theta##. We know that ##\beta(0) = 2\pi n## for some ##n##. As adding a constant does not effect the continuity of a function we can, wlog, take ##\beta(0) = 0##.
The technical point outstanding is that if ##\beta## is continuous, then ##\beta(\theta) = \theta##.
In general, we have ##\beta(\theta) = \theta + 2\pi n(\theta)## with ##n(0) = 0##, as above.
The only continuous functions of the form ##2\pi n(\theta)## are constant functions. I'll spare everyone an epsilon-delta proof of that. Therefore, we must have ##g(z) = i\theta = i\arg z## for ## 0 \le \theta < 2\pi##.
The second technical point is that ##\arg(z)## is discontinuous on the unit circle. I'll quote that as a known result.
In any case, that proves that ##g## cannot be continuous.
This is much more readable to me than your previous post. Your approach has all the right ideas. Especially the line "The only continuous functions of the form ##2\pi n(\theta)## are constant functions." is the key to an elementary approach that does not use black magic. I consider this question solved. Well done!
  • Haha
nuuskur said:
For every [itex]x\in\mathbb R[/itex] we have [itex]\mathbb P\{X\leq x\}\in \{0,1\}[/itex]. Let [itex]F[/itex] be the distribution function for [itex]X[/itex]. [itex]F[/itex] is right continuous and we have [itex]\lim _{x\to\infty} F(x) = 1[/itex] and [itex]\lim _{x\to -\infty}F(x) = 0[/itex]. This implies there exists [itex]c\in\mathbb R[/itex] such that [itex]F = I_{[c,\infty]}[/itex]. Now [itex]\mathbb P\{X<c\} = F(c-) = 0[/itex], therefore [itex]X=c[/itex] a.s.
Your first solution + the clarification in post #54 solves the question (I didn't look at the second one though)! Well done! I guess I must come up with less routine exercises since you seem to solve all of them ;)
@Infrared I wish to know... is #2 really as innocent as it looks? I was thinking IVT might be the only thing I need... on the other hand, it is bivariate (in a way) but the notion of continuity for many variables seems too strong for this problem. FYI you have the right to respond with your best "poker face."
  • Haha
My spider sense is tingling. [itex]\Gamma (z) / F(z)[/itex] is entire. Liouville's theorem? Or maybe the theorem that allows finit order entire functions without zeros be written as [itex]e^{P(z)}[/itex] for some polynomial [itex]P[/itex]. (Hadamard?)
It's not like I look at the exercise and come up with a solution. At some point I've done similar things, so it's a matter of reminding myself definitions/results and relevant techniques. As you can also see, I make mistakes, so it's not smooth sailing. Most of what I do is wrong, I have stacks of papers scribbled full of some gibberish and failed attempts at the problems in OP.
For question 15, should it be understood that it simply means that there is no solution where ##p, q, r \in \mathbb{Q}##?
Liouville, but not for the quotient.
Yes. There are certainly real solutions, but none with three rational numbers.
Hint: Reduce the question to an integer version of the statement.
benorin said:
@Math_QED +1 style point (and a like) for using the phrase "black magic" in reference to mathematics.
I think he gets that from me. I've been calling complex analysis black magic, because..well..it is :D
That said, @Math_QED , I gave a black magic approach in #32.
  • Love
It got lost in the sea of other posts haha. I will have a look.
@benorin Well, I can't prove that there isn't a totally elementary solution, but the proof I'm thinking of uses some tools a little more sophisticated than IVT, etc.
What I did:
I broke up ##p,q,r## into fractions of integers and expanded the exponential and added the fractions together. This would mean that the denominator and numerator of said fraction must be integers, but I don't know how to prove, or in this case, disprove that.
Mayhem said:
What I did:
It is a bit tricky. We can multiply the equation by its common denominator and get four new variables instead, but all integers. Then we can assume that the LHS and the RHS do not share a common factor. With this preparation we examine the equation modulo a suited number ##n##, i.e. we consider the remainders which occur by division by ##n##.
E.g. if ##3\cdot 6 + 11 = 29## then division by ##4## yields the equation ##3 \cdot 2 + 3 = 9 = 1 \, \operatorname{mod}4##.
fresh_42 said:
12. Prove ##{\overline{CP}\,}^{2} = \overline{AP} . \overline{BP}##
Pasted above is a redrawing of the original diagram with some triangles and angles highlighted for use in the proof. The proof is based on similarity of triangles ##\triangle{CAP}## and ##\triangle{BCP}##. Let ##\angle{BMA}=\alpha## and ##\angle{BMC}=\beta##. Note that triangles ##\triangle{BMA}##, ##\triangle{BMC}## and ##\triangle{CMA}## are all isosceles since ##\overline{MA} = \overline{MB} = \overline{MC}## as these line segments equal the radius of the circle. Since angles opposite equal sides of a traingle must be equal, it follows that
  • ##\angle{BAM} = \angle{ABM} = 90^{\circ} - \dfrac {\alpha} {2}##
  • ##\angle{CAM} = \angle{ACM} = 90^{\circ} - \dfrac {\alpha + \beta} {2}##
  • ##\angle{BCM} = \angle{CBM} = 90^{\circ} - \dfrac {\beta} {2}##
As per the original diagram, the line segment ##PC## is tangential to the circle. Therefore, ##\angle{PCM} = 90^{\circ} \Rightarrow \angle{BCP} = \angle{PCM} - \angle{BCM} = \dfrac {\beta} {2}##.
And ##\angle{CAP} = \angle{BAC} = \angle{BAM} - \angle{CAM} = \dfrac {\beta} {2}##.
Comparing the triangles ##\triangle{CAP}## and ##\triangle{BCP}##, we find that they must be similar (##\triangle{CAP} \sim \triangle{BCP}##) since they both have a common angle ##\angle{BPC}## and they also have another pair of corresponding angles, namely ##\angle{BCP} = \angle{CAP} = \dfrac {\beta} {2}##.
From the similarity of these triangles, it follows that all their corresponding sides must be of same proportion. Therefore,
$$\dfrac {\overline{BP}} {\overline{CP}} = \dfrac {\overline{CP}} {\overline{AP}}
\Rightarrow \overline{CP} . \overline{CP} = {\overline{CP}\,}^{2} = \overline{AP} . \overline{BP}
#55 for P7 might be found in the same waters.
  • Wow
Ok I was playing around with it a bit. Note that [itex]G(z) := F(z) - F(1)\Gamma (z)[/itex] is holomorphic on [itex]H(0)[/itex]. Since [itex]\Gamma[/itex] also satisfies the functional equation we have [itex]zG(z) = G(z+1)[/itex]. Note that [itex]G(1) = 0[/itex].
By the theorem in the link we have have an entire extension of [itex]G[/itex] to [itex]\mathbb C[/itex], call it [itex]g[/itex]. By assumption [itex]g(z)[/itex] is bounded for [itex]1\leq \mathrm{Re}(z)\leq 2[/itex]. This implies [itex]g[/itex] is bounded for [itex]0\leq \mathrm{Re}(z)<1[/itex]. We have [itex]1\leq \mathrm{Re}(z+1) < 2[/itex] so by assumption [itex]g(z) = \frac{g(z+1)}{z}[/itex] is bounded.
Put [itex]h(z) := g(z)g(1-z)[/itex], then it's clear [itex]h[/itex] is bounded for [itex]0\leq\mathrm{Re}(z)< 1[/itex]. This implies it's bounded in [itex]\mathbb C[/itex]. Indeed, we have by functional equation [itex]-zg(-z) = g(1-z)[/itex], which implies
[tex] h(z+1) = g(z+1)g(-z) = -zg(z) \cdot \frac{g(1-z)}{z} = -h(z).[/tex]
So we can start in the critical strip and remain bounded by induction. Thus [itex]h[/itex] is entire and bounded. By Liouville's theorem, [itex]h[/itex] is constant. Since [itex]h(1) = G(1)g(0) = 0[/itex] we must have [itex]g=0[/itex], hence [itex]F(z) \equiv F(1)\Gamma (z)[/itex].
HINT/IDEA: #2:
The intuition to use the IVT seems correct, but since there are two component functions, f,g, one seems to need the 2 dimensional version of this theorem, i.e. the winding number theorem: if a continuous map from (the boundary of) a polygon to the plane winds around a point a non zero number of times, then any continuous extension of that map to the interior of the polygon hits the point.
For the polygon, take the triangle bounded by (0,0), (2,0), (2,2) in the plane, and consider the map of that polygon to the plane defined by sending (a,b) to (f(a)-f(b), g(a)-g(b)). Try to show the boundary of the polygon (either meets (1,1), or) winds around the point (1,1) a non zero number of times. Remember that winding number is computed by adding up small angle changes, and use what is given. In fact all you need to know about winding numbers is it measures (1/2π times) the total angle change (in radians) swept out by an arrow based at the given point, and with head at a point on the path, as the point on the path runs all the way around the path.
  • Wow
Outstanding! I did notice at 21:12 what I think is an incorrect remark, that we supposedly don't know whether there are zeroes inside a square with winding number zero on the boundary. While true in general, it seems to be false in the example he was doing there, of a complex polynomial, since all winding numbers are non negative for such holomorphic maps, i.e. holomorphic maps are orientation preserving. In fact since winding numbers are additive over adjacent squares, if a square contains a zero, necessarily isolated, that zero will contribute a positive amount to the whole winding number, and there cannot be any negative winding numbers in that square to cancel it out. His mind no doubt reverted to the general principle as it applies to arbitrary continuous or smooth maps. I am pretty sure about this. So for a complex polynomial, I believe the winding number counts exactly the number of zeroes inside that square, each counted with its algebraic multiplicity. That multiplicity of course can also be defined as the winding number over a small enough square centered at that zero.
Forgive me for pointing out the one tiny error in an excellent presentation. Earlier I twice thought I had spotted errors and I turned out to be wrong both times. First he made a false conjecture, but then later he taught us that it is indeed false, and why. Then I thought he was wrong to say winding number 3, instead of minus 3, when the image path wound 3 times around zero clockwise, when mathematicians always prefer counterclockwise as positive. Then I realized he had also traversed the domain path clockwise, and what matters is that the image traverses the path in the same direction as the domain path, so both clockwise is the same as both counterclockwise, and +3 is indeed correct. On the last remark above however I believe he slipped up, although with good intentions of warning us of the situation in the general, not necessarily orientation preserving, situation. But complex holomorphic functions are especially nice.
That reminds me however that even there, there are situations where numbers that should ordinarily be positive, can still be negative. Namely in complex geometry, intersection numbers of holomorphic cycles are always positive, for the same reasons, except! in the oddball case where you are intersecting a cycle with itself! Then you are supposed to move the cycle and then intersect it. Only some cycles, "rigid" ones, do not move in the holomorphic category, they only move smoothly, and then you can get a negative self intersection number of a "rigid" holomorphic cycle with itself. E.g. if you "blow up" a point of complex P^2 to a line, then that blownup line, meets itself -1 times ! I.e. the corresponding line bundle does not have a section which is holomorphic, only one which is meromorphic, along that line. I.e. just as z winds once around zero, 1/z winds once around infinity, which is minus once around zero.
A basic result then in surface theory is you can recognize a line which can be blown down, because it has self intersection -1. A famous fact is that any smooth cubic surface in P^3 is isomorphic to the complex projective plane after being blown up at 6 general points. I.e. on any smooth projective cubic surface, there exist 6 disjoint lines (the choice of them is not unique) which all have self intersection -1, and such that, blowing them down results in a surface isomorphic to the projective plane! [In relation to another thread on stem reading, this sort of thing is why I love algebraic geometry.]
@mathwonk Very nice argument! One way to conclude that your loop has nonzero winding number is the following fact: If ##f:S^1\to S^1## is odd, then it has odd degree (and the same is true if ##S^1## is replaced by ##S^n##). Actually your geometry is good, and maybe this fact is just how it's usually formalized.
And you showed the stronger result that there are ##a,b## such that ##(f(a)-f(b),g(a)-g(b))## is actually ##(1,1)##, instead of just being a lattice point. In general, the problem statement will hold if and only if the prescribed values for ##f(2),g(2)## share a common factor (and of course there's no reason to make the functions defined on ##[0,2]##, I just did this for aesthetics).
nuuskur said:
In other words we have [itex]\{x\}= \bigcap _{n\in\mathbb N} \{U\subseteq X \mid x\in U,\ U\text{ is open and }f(U) \subseteq B(f(x), n^{-1}) \}[/itex].
I think there is a problem with your intersection, at least semantically. You have an intersection ##\bigcap_{n \in \Bbb{N}} A_n## with ##A_n \subseteq \mathcal{P}(X)##. Thus semantically your intersection is a subset of ##\mathcal{P}(X)##. However, the left hand side is ##\{x\}## which is a subset of ##X## (and not of ##\mathcal{P}(X))##. You might want to fix/clarify this.
Next, explain why the equality you then obtain is true (write out the inclusion ##\supseteq##).
we have the [itex]G_\delta[/itex] set
[tex] \bigcap _{n\in\mathbb N} \bigcup \left\{ U\subseteq X \mid U\text{ is open, }\ \sup_{u,v\in U} d_Y(f(u),f(v)) \leq n^{-1} \right \} = C(f).[/tex]
Explain this equality
I messed up there, even if the semantics is fixed, the logic breaks, because I was envisioning something that behaves too nicely. For instance, take a constant map. Fixing open sets [itex]x\in U_n[/itex] such that [itex]f(U_n) \subseteq B(f(x),n^{-1})[/itex] does not imply the [itex]U_n[/itex] become smaller around [itex]x[/itex] - contrary to what I had in mind. Disregard that part, entirely.
The equality in question is sufficient to solve the problem. Suppose [itex]f[/itex] is continuous at [itex]x[/itex]. Fix [itex]n\in\mathbb N[/itex]. Take the open set [itex]B(f(x),(2n)^{-1})[/itex] and it also satisfies the supremum condition (the diameter is twice the radius). By continuity at [itex]x[/itex], there exists an open set satisfying [itex]x\in U[/itex] and [itex]f(U) \subseteq B(f(x), (2n)^{-1})[/itex].
The converse reads exactly like the definition of continuity.
nuuskur said:
I messed up there, even if the semantics is fixed, the logic breaks, because I was envisioning something that behaves too nicely. For instance, take a constant map. Fixing open sets [itex]x\in U_n[/itex] such that [itex]f(U_n) \subseteq B(f(x),n^{-1})[/itex] does not imply the [itex]U_n[/itex] become smaller around [itex]x[/itex] - contrary to what I had in mind. Disregard that part, entirely.The equality in question is sufficient to solve the problem. Suppose [itex]f[/itex] is continuous at [itex]x[/itex]. Fix [itex]n\in\mathbb N[/itex]. Take the open set [itex]B(f(x),(2n)^{-1})[/itex] and it also satisfies the supremum condition (the diameter is twice the radius). By continuity at [itex]x[/itex], there exists an open set satisfying [itex]x\in U[/itex] and [itex]f(U) \subseteq B(f(x), (2n)^{-1})[/itex].
Indeed for this first set equality you needed something like injectivity which is not given.
Can you edit or make a new attempt at the question so everything reads smoothly? Otherwise everything is shattered through multiple posts making it very hard to read for others (and me when I go through it again).
Let [itex]C(f) := \{x\in X \mid f\text{ is continuous at }x\}[/itex] (may also be empty). It is sufficient to show [itex]C(f)[/itex] is a Borel set. Then [itex]C(f)^c = D(f)[/itex] is also a Borel set. We show [itex]C(f)[/itex] is a countable intersection of open sets. By definition, [itex]f[/itex] is continuous at [itex]x[/itex], if
[tex] \forall n\in\mathbb N,\quad \exists\delta >0,\quad f(B(x,\delta)) \subseteq B(f(x), n^{-1}).[/tex]
Note that arbitrary unions of open sets are open. We have the following equality
[tex] C(f) = \bigcap _{n\in\mathbb N} \bigcup\left \{U\subseteq X \mid U\text{ is open and } \sup _{u,v\in U} d_Y(f(u),f(v)) \leq n^{-1} \right \}.[/tex]
Indeed, let [itex]f[/itex] be continuous at [itex]x[/itex]. Take the open set [itex]B(f(x), (2n)^{-1})\subseteq Y[/itex]. By continuity at [itex]x[/itex], there exists an open set [itex]x\in U\subseteq X[/itex] satisfying [itex]f(U) \subseteq B(f(x), (2n)^{-1})[/itex]. We then have [itex]d_Y(f(u),f(v)) \leq n^{-1}[/itex] for all [itex]u,v\in U[/itex]. The converse inclusion reads exactly as the definition of continuity at a point.
