Math Challenge - December 2021
93 replies · 20K views · last reply
Sorry, please ignore my previous post (post #90). I think I found a mistake in that solution for question #31. I will attempt to find a correct solution later and make a new post.
You do not need an algorithm or any iteration. Consider pairs ##(g,P)## of a straight line in the plane and a point ##P\not\in g.## Then choose a pair such that ##\operatorname{dist}(g,P)## is minimal.
I didn't expect a reply to my withdrawn incorrect solution. 💯*💯*💯 thanks for that hint. Below is a solution, hopefully correct this time.
Geometry diagram of triangle ABC with A above line l1 through B, C and D, altitudes h_A[BC] and h_C[AD] marked, right-angle symbol at C, and dashed lines l1 and l2.
Let ##\mathcal{L} = \{l_1, l_2, ..., l_m\}## be the set of all lines that pass through 2 or more points belonging to ##\mathcal{P} = \{P_1, P_2, ..., P_n\}##. Suppose ##A \in \mathcal{P}, l_i \in \mathcal{L}## be a point and a line such that ##\mathtt{dist}(A, l_i) = \min \limits_{P_j \in \mathcal{P}} \min \limits_{l_k \in \mathcal{P}, P_{j} \notin_{l_k}} \mathtt{dist}(P_j, l_k)##. Such a pair will always exist if not all points of ##\mathcal{P}## are collinear. Without loss of generality, we will assume ##l_i = l_1## for convenience hereafter. By definition, ##l_1## will contain at least two points from ##\mathcal{P}##. We will prove that ##l_1## cannot contain more than 2 points from ##\mathcal{P}##, thus making it a line passing through exactly 2 points from ##\mathcal{P}##.
Let ##B, C## be the two closest points to ##A## among all points from ##\mathcal{P}## lying on ##l_1##. With reference to attached figure, ##h_{A[BC]} \equiv \mathtt{dist}(A, l_1)##, using the notation ##h_{X[YZ]}## to denote the height of vertex ##X## w.r.t. the base ##\bar {YZ}## in triangle ##\Delta {XYZ}##. Note that ##BC## must be the longest edge of ##\Delta ABC## (more precisely, no smaller than the other edges), since otherwise, we could have, for e.g., ##h_{B[AC]} \lt h_{A[BC]}##, i.e. distance between ##B## and line passing through ##A,C## is smaller than ##\mathtt{dist}(A, l_1)##, a contradiction. Therefore, ##\angle{ABC}, \angle{ACB}## must be acute angles as shown in the figure.
Now suppose there exists yet another point ##D \in \mathcal{P}## that lies on ##l_1##. Without loss of generality, we can assume that it lies to the right of point ##C##. Let ##l_2 \in \mathcal{L}## denote the line passing through ##A, D##. From the figure, we see that ##\mathtt{dist}(C, l_2) = h_{C[AD]}##. Using the area computation formulae for triangle ##\Delta {AQ_{1}D}##, it follows that ##h_{A[BC]} \times \mathtt{len}(Q_{1}D) = h_{C[AD]} \times \mathtt{len}(AD)##. Since ##\mathtt{len}(AD) \gt \mathtt{len}(Q_{1}D)## (as ##AD## is the hypotenuse of ##\Delta {AQ_{1}D}##), it follows that ##h_{C[AD]} \lt h_{A[BC]}##, i.e. ##\mathtt{dist}(C, l_2) < \mathtt{dist}(A, l_1)##. But this contradicts the initial assumption that ##\mathtt{dist}(A, l_1)## is the minimum possible distance between any point in ##\mathcal{P}## and any line in ##\mathcal{L}##. Since the contradiction arises only when we assume that there exists a point ##D## as defined above, it must be the case that such as point cannot exist. Hence, ##l_1## must contain only two points from ##\mathcal{P}##.
Once again I found a mistake in my solution. This time in one of equalities used in the proof. Posting the correction here.
To show that ##h_C[AD] < h_{A[BC]}## if a point ##D## exists as described in my previous post, I must have used an inequality since I was comparing two different triangles.
The area of ##\Delta AQ_{1}D## is ##\dfrac{1}{2} \times h_{A[BC]} \times \mathtt{len}(Q_1D)##. The area of ##\Delta ACD## is ##\dfrac{1}{2} \times h_{C[AD]} \times \mathtt{len}(AD)##. From the figure, it can be seen that the area of ##\Delta AQ_{1}D## must be larger than that of ##\Delta ACD##. Hence we get:
\dfrac{1}{2} \times h_{A[BC]} \times \mathtt{len}(Q_1D) > \dfrac{1}{2} \times h_{C[AD]} \times \mathtt{len}(AD) \Rightarrow h_{A[BC]} > \dfrac{\mathtt{len}(AD)}{\mathtt{len}(Q_1D)} \times h_{C[AD]}
Since ##\mathtt{len}(AD) > \mathtt{len}(Q_1D)## (as ##AD## is the hypotenuse of ##\Delta AQ_1D##), it follows that ##h_{A[BC]} > h_{C[AD]}##, i.e. ##\mathtt{dist}(A, l_1) > \mathtt{dist}(C, l_2)##, but this contradicts the initial assumption about the minimality of ##\mathtt{dist}(A, l_1)##.
The rest of the solution is the same as in the previous post.
