Math Challenge - May 2021
114 replies · 14K views
Staff Emeritus
Homework Helper
Insights Author
2025 Award
Summary: Group Theory, Integrals, Representation Theory, Iterations, Geometry, Abstract Algebra, Linear Algebra.1. Integrate
\int_{0}^\infty \int_{0}^\infty e^{-\left(x+y+\frac{\lambda^3 }{xy}\right)} x^{-\frac{2}{3}}y^{-\frac{1}{3}}\,dx\,dy
2. (solved by @Infrared , basic solution still possible ) Let ##F_n## be the free group of rank ##n## with generators ##\{w_1,\ldots,w_n\}.## Then
\prod_{i=1}^m w_{a_i}^{b_i} \in [F_n,F_n] \Longleftrightarrow \forall_{k=1}^m \;\sum_{a_i=k}b_i =0
3. (solved by @julian ) Calculate
\int_0^\pi \int_0^\pi \int_0^\pi \dfrac{1}{1-\cos x\,\cos y\,\cos z}\,dx\,dy\,dz
4. (solved by @fishturtle1 ) Let ##G## be a finite group, ##\mathbb{K}## a field such that ##\operatorname{char}(\mathbb{K})\nmid |G|,## and ##(\rho,V)## and ##(\tau,W)## linear representations of ##G## over ##\mathbb{K}.## The ##\mathbb{K}-##linear mapping
\begin{align*}
\operatorname{Sym}\, : \,\operatorname{Hom}_\mathbb{K}(V,W)&\longrightarrow
\operatorname{Hom}_\mathbb{K}(V,W)\\
\varphi &\longmapsto \operatorname{Sym}(\varphi)=\dfrac{1}{|G|}\sum_{g\in G}\tau(g)\circ\varphi \circ\rho(g^{-1})
\end{align*}
is a projection onto the subspace
\operatorname{Hom}_\mathbb{K}((\rho,V),(\tau,W))=\{\vartheta :V\longrightarrow W\,|\,\forall_{g\in G}\, : \,\tau(g)\circ\vartheta\circ \rho(g^{-1})=\vartheta \}
of ## \operatorname{Hom}_\mathbb{K}(V,W).## Determine and prove (mention) all five claims.
5. Let ##f(x)=x^3-\dfrac{49}{6}x^2+\dfrac{39}{2}x-\dfrac{31}{3}##. Prove that there are at least one ##a,b## such that ##f^2(a)=a\, , \,f(a)\neq a ## and ##f^4(b)=b\, , \,f^k(b)\neq b\;(k<4)## where ##f^n:=f\circ f^{n-1}, f^1=f.##
Is this true for every even power?
6. (solved by @etotheipi ) Prove the equivalence of the theorem of Pythagoras with the following transversal theorem about isosceles triangles:
Given an isosceles triangle ##\triangle ABC## with baseline ##\overline{AB}\subseteq g,## peak ##C,## i.e. ##|AC|=|BC|,## and ##g## the straight along the baseline. Moreover let ##P\in g## be an arbitrary point. Then
\begin{align*}
|CP|^{2}&=|CA|^{2}+|PA|\cdot |PB|\text{ if }P\not \in \overline{AB}\\
|CP|^{2}&=|CA|^{2}-|PA|\cdot |PB|\text{ if }P \in \overline{AB}
\end{align*}
7. (solved by @julian , another solution via MVT still possible ) Let ##\alpha ## be an algebraic number of degree ##n\geq 1.## Then there is a real number ##c>0## such that for all ##\mathbb{Q}\ni\dfrac{p}{q}\neq \alpha ##
\left|\alpha -\dfrac{p}{q}\right|\geq \dfrac{c}{q^n}
8. (solved by @etotheipi ) Let ##a_{n+1}=2+\sqrt{4+a_n}\, , \,a_0\geq -4\,,## be a sequence of real numbers. Determine - if existent - its limit in dependence of the initial value ##a_0,## and show that ##a_n\in [2,5]## in cases where ##a_0\in[-4,5],## and ##a_n\geq 5## in cases where ##a_0\geq 5## ##(n\in \mathbb{N}).##
9. (solved by @etotheipi ) Calculate center, foci, semi-axis, and area of the maximal inscribed ellipse of the triangle ##(1,1),(5,2),(3,6).##
10. (solved by @julian ) Let ##A,B\in \mathbb{M}(n,\mathbb{F})## be two square ##n\times n ## matrices over a field ##\mathbb{F}.## Show that the minimal polynomials of ##AB## and ##BA## are the same in case ##A## is regular. Is it true as well, if ##A## is singular?
High Schoolers only (until 26th)11. (solved by @kshitij ) For which positive real numbers ##\mathbb{R}\ni a,b>0 ## does
f(a,b)=\dfrac{a^4}{b^4}+\dfrac{b^4}{a^4}-\dfrac{a^2}{b^2}-\dfrac{b^2}{a^2}+\dfrac{a}{b}+\dfrac{b}{a}
assume a minimal value, and which one?
12. (solved by @kshitij ) Find all pairs ##(x,y)## of integers such that
y^2=x\cdot (x+1)\cdot (x+7)\cdot (x+8)
13. (solved by @kshitij ) Show that
\underbrace{\left|x-\dfrac{\sin(x)(14+\cos(x))}{9+6\cos(x)}\right|}_{=:f(x)}\leq 10^{-4}\text{ for } x\in \left[0,\dfrac{\pi}{4}\right]
You may use ##\pi =3.14159+\delta \, , \,\sqrt{2}=1.41421+\varepsilon ## with ##\delta,\varepsilon \in \left(0,10^{-5}\right).##
14. (solved by @kshitij ) If ##f(x)=a_nx^n+\ldots+a_1x+a_0\in \mathbb{R}[x]## is a real polynomial of degree ##n## which doesn't have real zeros, and ##h\in\mathbb{R}## a real number, then
F(x):=f(x)+h\cdot f'(x)+h^2\cdot f''(x)+\ldots+h^n\cdot f^{(n)}(x)
doesn't have real zeros either.
15. (solved by @kshitij ) Solve the following real equations system:
\begin{align*}
x+y&=az\\
x-y&=bz\\
x^2+y^2&=cz
\end{align*}
Problem 6. Let the angle ##\angle CAB = \angle CBA := \theta##. First consider ##P \in \overline{AB}##, then by the cosine rule $$|CP|^2 = |CA|^2 + |AP|^2 - 2|CA|\cdot|AP| \cos{\theta}$$Since ##|AB| = 2|CA| \cos{\theta}## then $$|AP|^2 - 2|CA| \cdot|AP| \cos{\theta} = |AP| \cdot\left( |AP| - 2 |CA| \cos{\theta} \right) = |AP|\cdot \left( |AP| - |AB| \right) = -|AP|\cdot |BP|$$hence ##|CP|^2 = |CA|^2 - |AP|\cdot |BP|##.
It's similar for ##P \not \in \overline{AB}##. WLOG take ##P## to be on the left of ##A##. Then\begin{align*}
|CP|^2 &= |CA|^2 + |AP|^2 - 2|CA|\cdot |AP| \cos{(\pi - \theta)} \\
&= |CA|^2 + |AP|\cdot \left( |AP| + 2|CA| \cos{\theta} \right) \\
&= |CA|^2 + |AP|\cdot \left( |AP| + |AB| \right) \\
&= |CA|^2 + |AP| \cdot|PB|
\end{align*}
Wait - I didn't really read the question and at second glance I don't think that's what it's asking. And on that note, I don't actually know what it means to prove equivalence with Pythagoras...
Oh, okay! In that case for the direction transversal ##\implies## Pythagoras you can just take ##P = D## (in which case ##|BP| = |AP|##). For the converse, consider first ##P \in \overline{AB}##. Then\begin{align*}
h^2 + |PD|^2 &= |CP|^2 \\
h^2 + |AD|^2 &= |CA|^2\end{align*}and so \begin{align*}
|CP|^2 &= |CA|^2 - (|AD|^2 - |PD|^2) \\
&= |CA|^2 - (|AD| + |PD|) \cdot (|AD| - |PD|) \\
&= |CA|^2 - |AP| \cdot |BP|
\end{align*}since ##|AD| + |PD| = |BD| + |PD| = |BP|## and also ##|AD| - |PD| = |AP|##. You also take the exact same approach for when ##P \not \in \overline{AB}##.
#10
The minimal polynomial of ##AB## is the unique monic polynomial ##p## of smallest degree such that ##p (AB) = 0##. Explicitly ##p (AB) = 0## reads:
a_0 \mathbb{1} + a_1 AB + a_2 (AB)^2 + \cdots + (AB)^m = 0 \quad (*)
Say ##A## is regular, multiplying from the left by ##A^{-1}## and from the right by ##A## gives
a_0 \mathbb{1} + a_1 BA + a_2 (BA)^2 + \cdots + (BA)^m = 0 ,
This is the smallest monic polynomial in ##BA## such that it is equal to zero. To prove this, suppose otherwise and assume that
q (BA) = b_0 \mathbb{1} + b_1 BA + b_2 (BA)^2 + \cdots + (BA)^l = 0 \quad (**)
where ##l < m##. Multiplying ##(**)## from the left by ##A## and from the right with ##A^{-1}## would result in ##q (AB) = 0##. A contradiction seeing as ##(*)## is the smallest monic polynomial in ##AB## that is equal to zero.
Is it not true as well, if ##A## is singular. Consider these two ##n \times n## matrices:
A =
\begin{pmatrix}
0 & \cdots & 1 \\
\vdots & & \vdots \\
0 & \cdots & 0
\end{pmatrix}
\quad
B =
\begin{pmatrix}
0 & \cdots & 0 \\
0 & \cdots & 1
\end{pmatrix}
Then
AB =
\begin{pmatrix}
0 & \cdots & 1 \\
0 & \cdots & 0
\end{pmatrix}
whereas
BA =
\begin{pmatrix}
0 & \cdots & 0 \\
0 & \cdots & 0
\end{pmatrix}
So ##BA = 0##. We have that ##(AB)^2 = 0##. So ##BA## has the minimal polynomial is ##p (z) = z##. And ##AB## has the minimal polynomial is ##p (z) = z^2##.
fresh_42 said:
8. Let ##a_{n+1}=2+\sqrt{4+a_n}\, , \,a_0\geq -4\,,## be a sequence of real numbers. Determine - if existent - its limit in dependence of the initial value ##a_0,## and show that ##a_n\in [2,5]## in cases where ##a_0\in[-4,5],## and ##a_n\geq 5## in cases where ##a_0\geq 5## ##(n\in \mathbb{N}).##
I'll try, I'm not so confident with these so some pointers would be appreciated. It is first worth to note that if ##a_0 \geq -4## then ##a_1 \geq 2##. And if ##a_k > 0## then ##a_{k+1} = 2 + \sqrt{4+ a_k} > 0## so all the ##a_k## for ##k > 0## are positive. Now consider\begin{align*}
|a_{n} - 5| = |\sqrt{4+a_{n-1}} - 3| &= \left| \frac{(\sqrt{4+a_{n-1}} + 3)(\sqrt{4+a_{n-1}} - 3)}{(\sqrt{4+a_{n-1}} + 3)} \right| \\ \\
&= \left| \frac{a_{n-1} - 5}{\sqrt{4+a_{n-1}} + 3} \right| \\
&\leq \frac{1}{5} \left| a_{n-1} - 5 \right| \\
&\leq \dots \leq \frac{1}{5^{n-1}} \left| a_1 - 5 \right|
\end{align*}So given any ##\epsilon > 0## we can choose ##N## as any integer greater than ##1 + \mathrm{log}_5 \frac{|a_1 - 5|}{\epsilon}## in order to have ##|a_n - 5| < \epsilon## for all ##n > N##, and the limit is hence ##L = 5## for ##a_0 \in [-4, \infty)##.
For the last bit I suppose you can just say that if ##a_0 \geq -4## then ##a_1 \geq 2## and if ##a_k \geq 2## then ##a_{k+1} = 2 + \sqrt{4+a_k} \geq 2##. Similarly, if ##a_k < 5## then ##a_{k+1} = 2 + \sqrt{4 + a_k} < 2 + \sqrt{9} = 5##. So all the terms with ##k > 0## will satisfy ##a_k \in [2,5)##.
And if ##a_k \geq 5## then ##a_{k+1} = 2 + \sqrt{4 + a_k} \geq 2 + \sqrt{9} = 5##, so for ##a_0 \geq 5## you have ##a_k \geq 5## for all ##k##.
Is it okay, or are there problems? 😜
Well, a bit sloppy a.u. The proof about the ranges would have required a monotony argument and/or an induction, and for the question about the fixed point, a consideration about uniqueness would have been nice.
Some idea on #8...
##\int_{0}^{\pi} \frac{1}{1-\cos x} \rightarrow \int_{0}^{\pi}\frac{1+\cos x}{1-\cos^2 x} \rightarrow \int_{0}^{\pi} \csc^2 x + \frac{\cos x}{\sin^2 x}## Which looks like it diverges, so if it's not suppose to diverge, this would be the wrong way to go about it
For #10, I'm confused why you specified that A is regular, it seems like the solution just uses that it's invertible. Are those the same thing?
It's the same in the finite-dimensional case. I have not really an idea about minimal polynomials and other properties in the infinite-dimensional case. Here it is bijective = isomorphism = invertible = non-singular = regular. At least I have learned it as such.
I was just playing around with number 9, I think if you subject the points to the following affine transformations:
- translate by ##(-1,-1)##
- then rotate by ##\frac{1}{\sqrt{17}}\begin{pmatrix} 4 & 1 \\ -1 & 4 \end{pmatrix}##
- then shear by ##\begin{pmatrix} 1 & \frac{-1}{4} \\ 0 & 1 \end{pmatrix}##
- then stretch by ##\begin{pmatrix} 1 & 0 \\ 0 & \frac{17\sqrt{3}}{36} \end{pmatrix}##
then you end up with an equilateral triangle with vertices ##\mathcal{V} \in \{ (0,0), (\sqrt{17},0), (\sqrt{17}/2, \sqrt{51}/2) \}##. The overall affine transformation is$$\begin{pmatrix} X \\ Y \end{pmatrix} = \begin{pmatrix} \frac{\sqrt{17}}{4} & 0 \\ \frac{-\sqrt{17}}{12\sqrt{3}} & \frac{\sqrt{17}}{3\sqrt{3}} \end{pmatrix} \begin{pmatrix} x-1 \\ y-1 \end{pmatrix}$$In the resulting equilateral triangle the maximal inscribed ellipse is just a circle of centre ##\mathbf{R}_C = (\sqrt{17}/2, \sqrt{51}/ 6)## and radius ##\mathscr{R} = \sqrt{51}/6##. The area of the original ellipse should simply scale as ##A_{\mathrm{ellipse}} = (\mathrm{det} \mathcal{M}^{-1})^2 A_{\mathrm{circle}} = \frac{1}{(\mathrm{det} \mathcal{M})^2} A_{\mathrm{circle}}##.
Also, the circle has equation ##\left(X - \frac{\sqrt{17}}{2} \right)^2 + \left(Y - \frac{\sqrt{51}}{6} \right)^2 = \frac{51}{36}##, so we can just substitute in for ##X(x,y)## and ##Y(x,y)## to find the equation of the ellipse.
I'm a bit tired to do remainder of the algebra now, though! :smile:
I want to see the center coordinates (up to 2 digits), foci coordinates (up to 2 digits), semi-axis (exact), area (exact). I need them to check whether it makes sense to read anything. No translated, rotated, or otherwise manipulated orbit equations. I am too lazy to decode the information from implicitly given equations.
Your integral diverges but the integral in the problem converges. A similar example is that ##\int_0^1\frac{1}{x^2}dx## diverges but ##\iiint_{x^2+y^2+z^2\leq 1}\frac{1}{x^2+y^2+z^2}dx dy dz## converges (use spherical coordinates).
  • Wow
That said... my ellipse is:$$F(x,y) := \frac{119}{108}x^2 -\frac{17}{54} xy + \frac{17}{27}y^2 -\frac{17}{3}x - \frac{17}{6}y + \frac{34}{3} = 0$$the centre can be found either by the inverse affine map from in #12 or simply by setting ##\nabla F(x_c, y_c) = 0## which gives ##(x_c, y_c) = (3,3)##. Is that what you got, as a start?
I haven't calculated the ellipse. The center is ##(3,3)##, yes.
I have for the semi-major, semi-minor and area:\begin{align*}
a &= \frac{\sqrt{2}(11+ \sqrt{13})\sqrt{11-\sqrt{13}}}{36} \\
b &= \frac{\sqrt{2}(11- \sqrt{13})\sqrt{11+\sqrt{13}}}{36} \\
A_{\mathrm{ellipse}} &= \pi ab\end{align*}the centre-to-focus length is ##c = \sqrt{a^2 - b^2}##. The focal points are then the ##(x_{f\pm}, y_{f\pm}) = (3 \pm c\cos{\theta}, 3 \pm c\sin{\theta})## where ##\cos{\theta}## and ##\sin{\theta}## satisfy\begin{align*}
\frac{119}{108} &= a^2 \sin^2{\theta} + b^2\cos^2{\theta} = (a^2 - b^2)\sin^2{\theta} + b^2
\end{align*}which could be found with a calculator, I guess 😄
Do you have any hints for the integral in problem 3? 😜 I could only tell so far that with ##x \mapsto u(x) = \pi - x## you see ##\mathcal{I} = \int_{\mathcal{D}} \frac{\mathrm{d}^3 x}{1-c(x)c(y)c(z) } = \int_{\mathcal{D}} \frac{\mathrm{d}^3 x}{1+c(x)c(y)c(z) } = \int_{\mathcal{D}} \frac{\mathrm{d}^3 x}{1-c(x)^2c(y)^2c(z)^2 }##...
I have different values, e.g. no ##\sqrt{13}.## And the area is a nice number, not a monster. You still deliver implicit solutions, instead of good old digits. However, I used a different method for calculation, so it's hard to compare them, especially as you didn't post what you had done exactly. E.g. the optimization process remains in the dark.
@Infrared already gave a hint. Weierstraß is another.
When I simplified my expression for ##A_{\mathrm{ellipse}}## using the exact expressions for ##a \sim 1.56## and ##b \sim 1.11## in post #19 I get ##A_{\mathrm{ellipse}} = \pi\sqrt{3}##. I didn't calculate the focal coordinates exactly but I have ##\boldsymbol{f}_{+} \sim (3.32, 4.05)## and ##\boldsymbol{f}_{-} \sim (2.68, 1.95)##
Hmm, okay I still don't know so I'll wait and see how someone else solves it! Weierstrass takes it to ##\mathcal{I} = 4\int_{\mathcal{D}'} (t^2u^2v^2 + t^2 + u^2 + v^2)^{-1} \, \mathrm{d} t \, \mathrm{d}u \, \mathrm{d}v## with ##\mathcal{D}' = (0, \infty)^{3}## but it also looks difficult to solve. :nb)
etotheipi said:
When I simplified my expression for ##A_{\mathrm{ellipse}}## using the exact expressions for ##a \sim 1.56## and ##b \sim 1.11## in post #19 I get ##A_{\mathrm{ellipse}} = \sqrt{3}##. I didn't calculate the focal coordinates exactly but I have ##\boldsymbol{f}_{+} \sim (3.32, 4.05)## and ##\boldsymbol{f}_{-} \sim (2.68, 1.95)##
You drive me crazy: sloppy a.u.! You dropped the ##\pi## in the area. The numbers are correct, except that I haven't checked ##a,b##. Anyway, since we now have a collection of posts with partial solutions, I will post mine for the sake of completeness, and in case someone wants to learn about the Steiner ellipse:
Set
\begin{align*}
\mathbb{C}[x]\ni p(z)&=(z-1-i)(z-5-2i)(z-3-6i)\\&=z^3 - (9 + 9 i) z^2 + (3 + 52 i) z + (33 - 39 i)
\end{align*}
The maximal inscribed ellipse of the triangle of zeros of ##p(x)## is thus the Steiner inellipse, where the sides of the triangle are tangents at their midpoints. The foci are the zeros of ##p'(z)## and the center the zero of ##p''(x)## by Marden's theorem.
\begin{align*}
0&=p'(z)=3 z^2 - (18 + 18 i) z + (3 + 52 i)\\
&=3\left(z- (3 + 3 i) - \sqrt{-1+\dfrac{2i}{3}}\right)\left(z- (3 + 3 i)+\sqrt{-1+\dfrac{2i}{3}}\right)\\
&\approx 3\left(z-3.32-4.05 i \right)\left(z-2.68 - 1.95 i \right)\\
0&=p''(x)=6\left(z-(3+3i)\right)
\end{align*}
Hence the center of the ellipse is ##(3,3)## and the foci ##(2.68,1.95),(3.32,4.05).## The area of an ellipse is given as ##A=\pi ab ,## so we have to compute the semi-axis of a Steiner inellipse within ##\triangle ABC## with center ##S.##
\begin{align*}
A=(1,1)\, , \,B=(5,2)\, &, \,C=(3,6)\, , \,S=(3,3)\, , \,\\
M:=\dfrac{1}{4}\left(\overline{SC}^2+\dfrac{1}{3}\overline{AB}^2\right)\, &, \,N:=\dfrac{1}{4\sqrt{3}}\cdot \left|\det\left(\vec{SC},\vec{AB}\right)\right|\\
a=\dfrac{1}{2}\left(\sqrt{M+2N}+\sqrt{M-2N}\right)\, &, \,b=\dfrac{1}{2}\left(\sqrt{M+2N}-\sqrt{M-2N}\right)
\end{align*}
\begin{align*}
M&=\dfrac{1}{4}\left(9+\dfrac{1}{3}\cdot 17\right)=\dfrac{11}{3}\\
N&=\dfrac{1}{4\sqrt{3}}\left|\det\left(\begin{bmatrix}
0&4\\3&1\end{bmatrix}\right)\right|=\sqrt{3}\\
a&=\dfrac{1}{2\sqrt{3}}\left(\sqrt{11+6\sqrt{3}}+\sqrt{11-6\sqrt{3}}\right)\\
b&=\dfrac{1}{2\sqrt{3}}\left(\sqrt{11+6\sqrt{3}}-\sqrt{11-6\sqrt{3}}\right)\\
ab&=\dfrac{1}{12}\left(\left(11+6\sqrt{3}\right)-\left(11-6\sqrt{3}\right)\right)=\sqrt{3}\\
A&=\pi\sqrt{3}\approx 5.44 \quad =\dfrac{\pi}{3\sqrt{3}}\cdot A_\triangle
\end{align*}
@fresh_42 does the answer to #1) involves ##\Gamma \left( \tfrac{7}{3}\right)##? I got that times a divergent integral but the calculus I did was slapdash, just want to know if I’m out on the correct limb here.
I have ##1## and ##2## as numerator, not ##7##, hence the answer is maybe.
Problem 1.
We have,
I=\int_0^{\infty}\int_0^{\infty}e^{-(x+y+\frac{\lambda^3}{xy})}x^{-\frac{2}{3}}y^{-\frac{1}{3}}dxdy
Make the following expansion under the integral sign,
e^{-\frac{\lambda^3}{xy}}=\sum_{n=0}^{\infty}(\frac{\lambda^3}{xy})^n\frac{(-1)^n}{n!}
to get
I=\int_0^{\infty}e^{-y}y^{-\frac{1}{3}}\int_0^{\infty}e^{-x}x^{-\frac{2}{3}}(\sum_{n=0}^{\infty}(\frac{\lambda^3}{xy})^n\frac{(-1)^n}{n!})dxdy
=\int_0^{\infty}e^{-y}y^{-\frac{1}{3}}\sum_{n=0}^{\infty}(\int_0^{\infty}(-1)^n(\frac{\lambda^3}{y})^n\frac{x^{-n-\frac{2}{3}}}{n!}e^{-x}dx)dy\\
Each x integral term in the expansion results in a Gamma function and taking the sum out side the remaining integral we get,
I=\sum_{n=0}^{\infty}(-1)^n\lambda^{3n}\frac{\Gamma (\frac{1}{3}-n)}{n!}\int_0^{\infty}e^{-y}y^{-n-\frac{1}{3}}dy
Again each term y integral term in the expansion results in a Gamma function.
I=\sum_{n=0}^{\infty}(-1)^n\lambda^{3n}\Gamma (\frac{2}{3}-n)\frac{\Gamma (\frac{1}{3}-n)}{n!}
By iterating each term in the sum using the identity,
\Gamma (n-1)=\frac{\Gamma (n)}{n-1}
we find,
I=1+\sum_{n=1}^{\infty}(-1)^n\frac{\lambda^{3n}3^{2n}\Gamma (\frac{1}{3}) \Gamma (\frac{2}{3}) }{\Pi_{k=1}^n (3k-1) \Pi_{k=1}^n (3k-2)n!}
Let ##x=3\lambda##. On expanding each term in the sum we find,
$$I=\Gamma (\frac{1}{3})\Gamma (\frac{2}{3})\sum_{n=0}^{\infty}(-1)^n\frac{x^{3n}}{(3n)!}
Let us seek a solution for ##y(x)=\sum_{n=0}^{\infty}(-1)^n\frac{x^{3n}}{(3n)!}## in the form of a second order differential equation. On expanding each term we have,
y(x)= 1-\frac{x^3}{3!}+\frac{x^6}{6!}-\frac{x^9}{9!}+...
y'(x)=-\frac{x^2}{2!}+\frac{x^5}{5!}-\frac{x^8}{8!}+...
y''(x)=-x+\frac{x^4}{4!}-\frac{x^7}{7!}+\frac{x^{10}}{10!}-\frac{x^{13}}{13!}+...
We observe,
y''-y'+y=e^{-x}
The characteristic polynomial for the homogeneous solution is,
\lambda^2-\lambda + 1=0\\
and thus,
\lambda=\frac{1}{2}\pm \frac{i\sqrt{3}}{2}\\
with the homogeneous solution,
y_h(x)=e^{\frac{x}{2}}[c_1\cos(\frac{\sqrt{3}x}{2})+c_2\sin(\frac{\sqrt{3}x}{2})]
The particular solution is of the form,
y_p=Ce^{-x}
Plugging this into the differential equation we find ##C=\frac{1}{3}##. The solution is the sum of the homogeneous part and the particular part,
y(x)=y_h(x)+y_p(x)
Applying the boundary conditions ##y(0)=1## and ##y'(0)=0## we find ##c_1=\frac{2}{3}## and ##c_2=0##. Thus
y(x)=\frac{2}{3}e^{\frac{x}{2}}\cos(\frac{\sqrt{3}x}{2})+ \frac{1}{3}e^{-x}
and we finally have,
\int_0^{\infty}\int_0^{\infty}e^{-(x+y+\frac{\lambda^3}{xy})}x^{-\frac{2}{3}}y^{-\frac{1}{3}}dxdy=\Gamma (\frac{1}{3})\Gamma (\frac{2}{3})[\frac{2}{3}e^{\frac{(3\lambda)}{2}}\cos(\frac{3\sqrt{3}\lambda}{2})+ \frac{1}{3}e^{-3\lambda}]$$
Fred Wright said:
Problem 1.
We have,
to get
we find,
We observe,
y''-y'+y=e^{-x}
and thus,
y_p=Ce^{-x}
y(x)=y_h(x)+y_p(x)
Can you simplify this expression? A lot! Will say: 1 ##e##, 1 ##\pi## , 1 ##\lambda ##, 1 ##\sqrt{{}}##, 0 ##\Gamma## I think you made a mistake. My integral is far easier. The cosine term appears to be wrong.
Damn I was working integral transformations not series expansions. I shouldn’t have put my pencil down!
That is my approach, too. The series solution seems to have a mistake somewhere. There is a useful trick to solve the integral quite easily.
I get
$$I=36\sum_{k=0}^\infty (-1)^k\tfrac{\lambda ^{3k}}{(3k-1)(3k-2)}$$
as a series solution for the integral using integral transformations and series expansions and Beta functions to finish it off.
