Minimizing Area: Proof that k is Independent of f(x) in a Tangent Problem
  • Thread starter Thread starter elsen_678
    Tangent
The discussion focuses on proving that the value of k, which minimizes the area bounded by a concave down curve y=f(x) and its tangent line between points A and B, is independent of the function f(x). Participants emphasize the importance of visualizing the problem through sketches to clarify the relationships between the curve, tangent, and bounding lines. There is a call for more specificity in the question to facilitate assistance. The conversation highlights the need for a structured approach to the proof rather than simply seeking a solution. Overall, the thread encourages deeper engagement with the problem to achieve understanding.
elsen_678
the graph of y=f(x) is concaved down over the interval (A,B)
ie f''(x)<0 for A=<x=<B
the tangent of the curve at point P(k,f(k)) meets lines x=A and x=B at P and Q respectively.
the value of k is such that the area bounded by the curve, the tangent and lines x=A and x=B is minimized.
Prove that k is independent of f(x).
somebody helps thanks
Do you have no clue at all?
Begin with a drawing of the situation. Try to be more specific in your question. We're not going to do the problem for you...
sketch
i have done some sketche
