Matlab multiple curves on same graph
To plot multiple curves in MATLAB for the function y=x^i where i ranges from 1 to 10, the initial code only plots the last curve due to overwriting the variable y. To resolve this, the code should store each curve in a matrix by using y(i,:) = x.^i within the loop. After calculating all curves, the plotting can be done by first plotting the first curve and then using a loop to plot the remaining curves while holding the graph. This method ensures that all ten curves appear on the same graph. Properly managing the data structure allows for effective visualization of multiple functions in MATLAB.
sara_87
Hi all,
I am trying to plot multiple curves in matlab.
If i have the function:
y=x^i
where i goes from 1 to 10.
I want to plot the function y for each i.
x=[1 2 3 4 5 6 7 8 9 10]
for i =1:10
y = x.^i
end
plot(x,y)
this returns 10 sets of the answer y. I want to plot these 10 curves on the same graph.
the above code only plots x against y for the last case (when i=10)
any help would be very much appreciated.
thank you
sara_87 said:
Hi all,
y=x^i
for i =1:10
y = x.^i
end
plot(x,y)
thank you
You can change your code to:
for i =1:10
y(i,:) = x.^i
end
plot(x,y(1,:))
hold on
for i = 2:10
plot(x,y(i,:))
end
hold off
