Converting Excel Spreadsheet to Matrix and Storing in Mfile
In summary, the user is looking for a way to convert a matrix in their command window to a specific format, and wants to know if they can store the matrix in a file for future use without relying on the original spreadsheet. The suggested solution involves using the fprintf and save functions.
elbarto
33
Hi
I have just imported a fairly large matrix from a excel spread sheet (121x6) useing the xlsread function. Is there a way I can convert the matrix from my command window to look something like below.
Matrix = [...; ...; ...; ...; ...; ...]
I want to know if i can store the matrix in a mfile so I can use the data even if i no longer have access to the spreadsheet. I don't really want to use xlsread everytime i need to use the matrix and I want to be able to run the code on different machines if i need.
Thanks in advance
Elbarto
It can be done in this way (your array is arr)
Code:
[m n] = size(arr);
for i = 1:m
fprintf([num2str(arr(i,:)) ';'])
end
The fprintf prints everything in the same line. num2str converts integer to string. arr(i,:) extracts each row of the matrix. Following are some references:
https://in.mathworks.com/matlabcentral/answers/116593-how-to-display-a-string-and-matrix-in-matlabhttps://in.mathworks.com/matlabcentral/answers/175231-extract-first-row-from-matrixhttps://in.mathworks.com/matlabcentral/answers/16963-how-to-print-in-the-same-line
This can be done using the save function:
https://in.mathworks.com/help/matlab/ref/save.html
Related to Converting Excel Spreadsheet to Matrix and Storing in Mfile
What is the process of converting an Excel spreadsheet into a matrix in an Mfile?
The process of converting an Excel spreadsheet into a matrix in an Mfile involves several steps. First, the spreadsheet data must be organized into a table format, with rows representing the observations and columns representing the variables. Then, the data must be copied and pasted into an Mfile. Finally, the data must be formatted into a matrix using the appropriate functions and syntax.
What is the benefit of converting an Excel spreadsheet into a matrix in an Mfile?
Converting an Excel spreadsheet into a matrix in an Mfile allows for easier manipulation and analysis of the data. Matrices are a common data format used in scientific computing and can be easily manipulated using various functions and operations. Additionally, storing data in an Mfile allows for easier access and organization of the data.
What is the difference between a spreadsheet and a matrix?
A spreadsheet is a data format commonly used in programs like Microsoft Excel, where data is organized into rows and columns. A matrix, on the other hand, is a data structure used in scientific computing, where data is organized into rows and columns and can be manipulated using various functions and operations. While spreadsheets are useful for data entry and basic analysis, matrices are more versatile and efficient for complex scientific computations.
Can any type of data be converted into a matrix in an Mfile?
Yes, most types of data can be converted into a matrix in an Mfile. However, the data must first be formatted into a table format with rows and columns. Additionally, the data must be numeric or can be converted into numeric form, as matrices can only store numerical data.
How can I store a matrix in an Mfile for future use?
To store a matrix in an Mfile, you can use the "save" function in MATLAB. This function allows you to save the current workspace variables, including your matrix, into an Mfile. You can then load the Mfile in the future to access and use your stored matrix.
  • Atomic and Condensed Matter
  • Computing and Technology
28K
